SP3 - Two sub channels possible?
0 Members and 1 Guest are viewing this topic. Read 1489 times.
derekcooper
« on: 4 Mar 2019, 04:37 pm »
Hey Brystoners,
Is that a word, "Brystoners?"
Setting up a HT with the SP3 and looking to run two subs in a 5.2 configuration. Unfortunately, the subs do not have out ports, so they can't be daisy-chained. Is there a way to assign one of the unused balanced-out ports on the SP3 to act as a second sub port?
Derek
derekcooper
Re: SP3 - Two sub channels possible?
« Reply #1 on: 4 Mar 2019, 04:58 pm »
Don't you hate when you embarrass yourself and find the answer after you post? It appears as though I can assign AUX OUTPUTS to SubWoofer...  :duh:
gbaby
« Reply #2 on: 7 Mar 2019, 04:18 pm »
I have been using an aux output for a second sub for years. It makes a difference.  :D
ragg987
« Reply #3 on: 11 Mar 2019, 12:22 pm »
I had been using Aux-L and Aux-R previously - see my setup and impressions here
https://www.audiocircle.com/index.php?topic=116297.0][url]https://www.audiocircle.com/index.php?topic=116297.0[/url]
I have since moved house and some aspects of my system are changed, but more importantly am now using the single .1 output of the SP3 to drive both subwoofers using a Y-adaptor. I cannot comment if it is better, but I am happy with the result and using the .1 gives much better control of the subs. The Aux outputs have limited control options, plus there is a delay in timing compared to the mains which makes setting phase tricky.
dminches
« Reply #4 on: 27 May 2019, 10:41 pm »
If one selects 7.1 bypass as the input source will the 2nd sub connect to either the XLR sub output or the AUX-L output receive a signal?
stanb
« Reply #5 on: 28 May 2019, 04:21 pm »
Hi dminches,
AUX-L/R should output the sub (and centre) but it will be the same sub signal as going out from the XLR sub output.
Stan
dminches
« Reply #6 on: 28 May 2019, 05:49 pm »
Hi dminches,
Stan
Great.  So it sounds like one can get 7.2 output from the 7.1 bypass input.  Is that correct?
