0 Members and 1 Guest are viewing this topic. Read 5872 times.
I just got Widex hearing aids last Oct and it has made a difference in being able to hear conversations. I was worried that it would be a negative to my music listening, but it has actually helped.S Clark,I would like to hear more about what you did to improve the performance of your hearing aids.
Which ReSound are you trying? Quattro? They are top on my list so far for my three year replacement in a few months. Costco should have a version before the end of the year at half that price or less.
... it's probably time I addressed my hearing and not the system. Steve
Yes, the Quatro. I have read that the CostCo unit is not exactly the same... but it sure is cheaper. If you decide to buy a pair, let me know. I'll PM you the contact info for my provider. ReSound might be willing to share with CostCo some of the modifications they did with my unit.
Thanks to all for your responses. While this thread took a left turn from where I started (aids vs amps) it's probably time I addressed my hearing and not the system. Steve
"Are you reading about a Costco version that will be coming? I don't think they have it yet."No, I just read somethiing about Costco units are not serviceable in the same way as private provider units. Don't remember exactly where that came from, but I'll try to verify it.
