0 Members and 1 Guest are viewing this topic. Read 5873 times.
I receive at least one Hearing Aid ad per week it seems. Are you aware of any brands that work well for music?
There is no need to spend a fortune on sources unless you want the user interface they offer or you must have native playback. It's much less expensive just to add a good reclocker. You can get 7psec of jitter at the end of the coax cable for just $699. Noone seems to mind the resampling and 99% cannot even tell the difference between a low-jitter native track and resampled track, given the right reclocker.Steve N.Empirical Audio
If you are using hearing aids, you should just go to headphones.
I resist because as roscoe65 said, it makes no sense to have a nice audio system that would get played through a hearing aid.
