**SOLD** KEF Q150 Bookshelf Speakers - Brand New Factory Sealed Pair (Black)
0 Members and 1 Guest are viewing this topic. Read 1122 times.
sean619
These KEF Q150 speakers are brand new & factory sealed in the box. The finish is black. Priced as a PAIR of speakers. Speaker grills are sold separately.
Asking Price:   $449.00
I will cover the Paypal fees.
Audiogon user: seanheis1
Will Ship to US and Canada. Can do local sale in Seattle area
Thanks for looking!
Specifications
Design: Two-way bass reflex
Drive Units: Uni-Q driver array:
HF: 25mm (1in.) vented aluminium dome
LF/MF: 130mm (5.25in.) aluminium Uni-Q
Frequency Range Free Field (-6dB): 47Hz
Frequency Response (±3dB): 51Hz - 28kHz
Crossover Frequency: 2.5kHz
Amplifier Requirements: 10-100W
Sensitivity (2.83V/1m): 86dB
Maximum Output: 108dB
Nominal Impedance 8é (min.3.7é)
Weight 5,6kg (12.3 lbs)
Dimension (H X W X D) 303mm (11.92 inches) x 180mm (7.08 inches) x 278mm (10.944 inches)
Dimension (H X W X D) *with Rubber Feet 307mm (12.08 inches) x 180mm (7.08 inches) x 278mm (10.944 inches)
From the Manufacturer:
The remarkable Q Series bookshelf speakers excel when space is limited. Featuring the signature KEF Uni-Q driver array with Computational Fluid Dynamics (CFD) port design, the Q150s deliver detailed natural sound with high clarity and tight bass.
"Sit anywhere" Uni-Q Sound
At the heart of the evolved Q Series is the Uni-Q driver array. KEF's signature innovation places the tweeter in the acoustic center of the midrange cone, bringing the acoustic ideal of a single point source closer than ever to realisation. The result is a more detailed, more accurate three-dimensional sound image, which is dispersed more evenly throughout the room than is possible with a conventional speaker. Uni-Q's ultra-wide dispersion is further enhanced by KEF's 'tangerine' waveguide over the tweeter dome.
Uni-Q sound taken to the next level
To optimize the resolution and purity of the Q Series bookshelf speaker, the Uni-Q driver has been repositioned to the center of the cabinet to reduce unwanted internal resonance and adds refinement to their sonic clarity and detail. With the addition of the Damped tweeter loading tube providing a gentle termination of sound produced from the back of the tweeter, lower treble performance is improved dramatically and a new low-distortion inductor on the crossover provides cleaner bass response.
CFD Designed Port
Featuring a Computational Fluid Dyanmics (CFD) port design with the port repositioned to the rear of the speaker, clarity is improved by reducing the audibility of the midrange leakage through the port. The geometry of the ports have been tuned to minimize turbelence at higher levels resulting in a reduction in port noise and less LF compression.
These speakers compete very well against bookshelf speakers from Focal, Klipsch, ELAC, SVS, Paradigm, PSB, Monitor Audio, Martin Logan, Bose, and B&W
« Last Edit: 8 Apr 2019, 09:06 pm by sean619 »
sean619
sean619
sean619
bump
sean619
bump
sean619
bump
