Fet Valve 400R question
0 Members and 1 Guest are viewing this topic. Read 1193 times.
supermo26
« on: 21 Feb 2019, 11:34 pm »
So I have this amp that I got used. I'm not sure if I have the instruction or not so I figured I'd ask here.
There is a switch on the back that says "chassis ground" and On and Off. What does this do. Mine was off when I got it and it is still off, Do I need to turn it on?
Lefty052347
  • AVA Associate
Re: Fet Valve 400R question
« Reply #1 on: 21 Feb 2019, 11:48 pm »
NO.
That's a ground loop switch.  Turn on to eliminate ground loop (hum) if it occurs.
Dean
supermo26
« Reply #2 on: 21 Feb 2019, 11:54 pm »
Thank you. No hum so i'll leave it alone.
avahifi
    • http://www.avahifi.com
« Reply #3 on: 22 Feb 2019, 09:04 pm »
Leave the ground lift switch turned ON unless you have ground loop hum issues.
Frank
