0 Members and 1 Guest are viewing this topic. Read 6771 times.
No images are showing up for me.
I dont mind spending few hundred usd on better caps if this actually improves the sound, but does it?
The thing I've found with Caps - if there's signal going through it, then you ought to use something made of copper. I've tried copper caps from Audyn, Jupiter and Miflex. IMO the Miflex caps the best of the lot and are also the cheapest.And if you think about it, it makes sense. You wouldn't make an interconnect or speaker wire out of aluminum or tin, would you? If not, then why would you use signal caps with tin or aluminum? Copper all the way baby!
Did you use the KPCU (copper oil) or the KFPM (copper poly) caps?Randy
I just read the review of the Miflex on Humble Homemade Hifi. Tyson, what did you think of that review's comparison with the Jupiter? What are your thoughts on the Jupiter comparison relative to HHH? I have Jupiter's as output caps in my preamp, but have had reliability issues with them and have been curious to try another brand if I can find one that's as good as the Jupiters for equal or lesser cost. Don't think Duelunds would fit physically or in the pocketbook.
