DIY Class T Amp, 30wpc, $40+Shipping
0 Members and 1 Guest are viewing this topic. Read 822 times.
G.Michael
« on: 19 Feb 2019, 09:51 pm »
Built in a leftover Acopian chassis.  Way overkill power supply.  Supply voltage: 27 VDC.  The Class T boards are from Helder HiFi.
It's a nice low-wattage yet dynamic amplifier.
Selling it mostly for the cost of parts.  $40 plus shipping.  (It has a hefty power supply, the whole unit weights upwards of 20 lbs.  So figure $20-$30 shipping from 18104.)
« Last Edit: 20 Feb 2019, 05:21 am by G.Michael »
almonduck
Re: DIY Class T Amp, Good Quality, 30wpc
« Reply #1 on: 20 Feb 2019, 04:45 am »
Very cool. With a little passive pre it would make a great energy saving system. I'm interested. PM sent. Any thoughts on how to further upgrade or mod it?
G.Michael
Re: DIY Class T Amp, 30wpc, $40+Shipping
« Reply #2 on: 20 Feb 2019, 05:33 am »
Well, you could add more channels (outboard), as the power supply can deliver plenty of current.  BTW, I have a couple more Class T boards available.
Speaking of a passive preamp and low power consumption, I have another one of these--different chassis, lesser-quality power supply, but same Class T boards.  I put a stepped attenuator at the input, and I wired it up so that I can bypass the internal power supply and run the unit on a 24VDC battery supply.  These Class T boards running on battery give a super low background noise.  And using a good linear supply, you get a little better dynamics.    So, a tradeoff.
celo
« Reply #3 on: 20 Feb 2019, 05:36 am »
Which chip, do you know? TA20xx?
G.Michael
« Reply #4 on: 20 Feb 2019, 05:49 am »
STA-508.  Take a look: https://www.tnt-audio.com/ampli/helder_sta508_e.html
BTW, in my various builds with these Class T boards, I found they work very well driven by the Pass Labs B1 buffer.  In that particular assembly, I ran both the Class T boards and the B1 buffer board on 26VDC.
