Bobs devices SKY 20 step up transformer for VPI tonearm
0 Members and 1 Guest are viewing this topic. Read 1373 times.
peckjed
Pretty much mint condition Bobs devices SKY 20 step up transformer for VPI tonearms. Mounted once, and used sparingly. This is the new revision that has several mounting holes in the bottom for different spacing.
New 1700!
$1350 OBO + PayPal fees/shipping (if applicable)
Info from bobs site:
This fully integrated Step-up Transformer/VPI Interface Box was specifically created to improve the performance of your VPI turntable when used with a low output Moving Coil Phono Cartridge. It replaces the standard VPI Interface Box with a unit that combines the top of the line Bob's Devices exclusive "Blue Series" CineMag 1131 Step Up Transformers with the VPI Interface Box.
This unit eliminates a set of interconnects and connectors in the phono playback circuit. The path between the moving coil cartridge and the phono preamplifier is as critical as it is sensitive due to the low voltage and current being transmitted. Further, this path is also subject to RF and other interference. You will hear the difference by streamlining this path - "the fewer stones in the road the smoother the ride."
This Bob's Devices VPI-SUT replaces the standard VPI interface box on the following arms where the interface box is directly attached to the tonearm base/platform : JMW 12.7, JMW 12.6, JMW 12.5, JMW 9T, JMW 9S, JMW C2, JMW C3, Classic, JMW 10, and JMW 10.5i (and other heritage JMW arms - contact us for specific applications). It will not work where the interface box is mounted directly to the plinth.
You will, “Hear the Magic!”
Comes with detailed installation instructions, or you are welcome to have Bob install this device if you feel uncomfortable doing so. Just email Bob at [email protected] for shipping instructions. Basically you could just send the Tonearm Base and Bob will replace the VPI interface Box with the Bob's Devices VPI-SUT.
advanced101
Re: Bobs devices SKY 20 step up transformer for VPI tonearm
« Reply #1 on: 18 Feb 2019, 12:51 pm »
Not sure if you are on VPI Forums but they have a Classified thread under Mat's Corner.  Might want to put it there too.  GL
http://vpiforum.com/viewforum.php?f=10&sid=0bbbcf5c41271b5644bd799993550b25
orthobiz
« Reply #2 on: 19 Feb 2019, 10:51 pm »
OK, so on the website there is a lift/ground switch AND a high/low switch. I have two tonearms, only one with a Denon 103 cartridge. The other has the VPI-specific Zephyr cartridge, so this box would not be usable for both cartridges? (Pardon my ignorance...)
Paul
peckjed
« Reply #3 on: 19 Feb 2019, 10:53 pm »
This actually just sold. (Woohoo!). The lift is a ground lift. It doesn’t let you bypass the Stepup. If that was the case I’d have kept it for the MM cart I plan on moving to. Lol.
orthobiz
« Reply #4 on: 19 Feb 2019, 10:57 pm »
Ohhh...thanks, glad you sold it!
Paul
