*SOLD* Parasound Zdac v.2 - Preamp, Headphone Amp & DAC - V2 - Rare Silver Color
0 Members and 1 Guest are viewing this topic. Read 868 times.
sean619
This Parasound Zdac v.2 is in like new condition. Very little use so I am selling.
The separate volume controls for headphones and RCA/XLR outputs is very convenient if you plan to use headphones and speakers with this device.
Top quality built product and excellent sounding, this is a very refined DAC, preamp, and headphone amp.
Original Factory Double Box and Packaging
I will cover the Paypal fees.
Audiogon user: seanheis1
Will Ship to US and Canada. Can do local sale in Seattle area
Price: $295
Thanks for looking!
Reviews:
https://www.innerfidelity.com/content/parasound-zdac-v2-and-headphone-amp#zYijLM13TItvSpOI.97
http://www.enjoythemusic.com/magazine/equipment/0115/Parasound_Zdac_v2_DAC_Headphone_Amplifier_Review.htm
Includes:
Factory double box & packaging material
Power cable
USB cable
Features:
• Analog volume control for RCA and XLR outputs
• Separate volume control for the headphone Jacks
• Digital audio connection to LightingTM jack-equipped Apple® devices (USB adapter required)
• Updated headphone amp with increased gain
• 1/4" and 1/8" 24k gold plated headphone jacks
• 12V input and output triggers
• Volume control lock out switch
• Premium Analog Devices AD1853 24-bit/192 kHz Digital to Analog Converter IC
• All inputs feature jitter reduction and are re-clocked and up-sampled to 422 kHz / 24 bit
• USB input for playing music from PC or Mac (driver-less for easy setup)
• Asynchronous sample rate conversion for all inputs including the USB input
• Works with any format file on your computer up to 96 kHz / 24 bit
• Optical and Coaxial digital inputs for use with any standard digital connection
• RCA unbalanced and XLR balanced analog outputs
• High current headphone output with volume control can drive any headphones from 32 to 600 ohms
• Oversized internal toroid power transformer (not a wall wart like many competitors)
• Will always power back up to the same input in the event of an AC power outage
Specs:
Supports Incoming Digital Word Lengths:
16 bit - 24 bit
Supports Incoming Digital Sampling Frequencies:
Opt & Coax: 8 kHz, 11.025 kHz, 16 kHz, 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz.
USB: 44.1 kHz, 48 kHz, 88.2 kHz and 96 kHz
Upsampling Frequency:
422 kHz / 24 bit (all inputs)
USB Streaming Controller:
Texas Instruments TAS1020B
Sample Rate Converter:
Analog Devices AD1895
D to A Converter:
Headphone Amplifier:
Texas Instruments TPA6120
Frequency Response:
20 Hz to 20 kHz ±0.2 dB
Channel Balance:
< 0.05 dB, 20 Hz - 20 kHz
Channel Separation:
> 95 dB, 20 Hz - 20 kHz
Signal to Noise Ratio:
110 dB, A-weighted
THD + Noise:
< 0.015 %
Audio Output Level, RMS (maximum):
Unbalanced Variable: 2.4 V
Balanced Variable: 4.8 V
Unbalanced Fixed: 2.2 V
Balanced Fixed: 4.4 V
Output Impedance:
Line out: 160 ohms, unbalanced or balanced
Headphone out: 10 ohms
AC Power Requirement:
110-130 VAC 60 Hz or
220-240 VAC 50 Hz (voltage is selected on the chassis bottom)
Operating: 10 watts
Standby: < 1 watt
Dimensions:
Width: 8.5" (220 mm)
Depth: 10" (254 mm)
Height: 2" (51 mm) with feet, 1.75" (45 mm) without feet
Weight:
Net: 5 lbs (2.3kg)
Shipping: 8 lbs (3.7kg)
Similar products: BENCHMARK DAC3 BENCHMARK DAC2 BENCHMARK DAC1 Mytek Brooklyn DAC Chord Qutest Schiit
« Last Edit: 14 Feb 2019, 02:21 am by sean619 »
