0 Members and 1 Guest are viewing this topic. Read 26511 times.
SW1X USB to Spdif convertors are based on Abbas Audios boards and tech. They work together.
You didn't mention in your original post why you don't want to use USB. It can be well implemented, but potentially noisy for very high efficiency systems. I currently use the original Sonore SSR (Rendu). Ethernet to s/pdif or i2s converter. Sonore quickly discontinued it as everyone wanted Ethernet to USB (microRendu). I had previously used the Hiface Evo. It requires the battery option to sound it's best, but still doesn't compete with the SSR.
I use an excellent Kingrex USB converter (discontinued) but if it ever died I would try the WaveIO board ($112.65). The WaveIO is used in the high end DDDac kithttp://luckit.biz/Some background on USB recievers: http://www.dddac.com/dddac1794_usb.htmlWayne,Thank you for posting this. I glanced at the converter offered at luckit.biz and have a couple questions. Is any soldering required?Can I just add a case, add appropriate PS, plug in wires/cables and begin using it?
