AKSA manual and Nirvana details?
0 Members and 1 Guest are viewing this topic. Read 2127 times.
Johnny
« on: 25 Jan 2005, 06:08 pm »
Greetings all!
I've had my AKSA 55 in service for 2.5 delightful years now. (Guess the caps must be broken in by now!)
Is the "new and improved" construction manual available somewhere on line- eg. as a pdf? It would be nice to have it to refer to.
Also, I'm tempted by a Nirvana upgrade, but I'm not clear on the kit details. Can someone elucidate:
1) What components are involved in the N and N+ upgrade?
2) How much more "work" is involved in the N+?
(Probably evident in the answer to #1)
TIA
John
PSP
« Reply #1 on: 25 Jan 2005, 07:18 pm »
Hi John,
Hugh, being rightfully cautious regarding his intellectual property--so he can eat, feed his family, etc.--provides detailed instructions, schematics, and all that only to people who purchase his kits and upgrades.
I've done the Nirvana upgrade to all three of my AKSA 55's, but it's been a couple of years at least.  My seat-of-the pants estimate is that the Nirvana upgrade replaces maybe 20-30% of the original parts with upgraded parts.  It took me several evenings to complete each one, but I work slowly.
The N+ upgrade replaces only a few key parts (and slightly modifies the circuit)... this could be completed in an evening or two, even at my slow soldering rate.  The N+ mods are as easy as it gets in DIY.
In both cases (N and N+) you need to re-bias the amp... the changes are small, but you will want to be sure.
The sonic impact of the Nirvana upgrade is anything but subtle.  You will hear more clarity and transparency in the highs, more definition and impact in the bass.
In my system and to my ears, the N+ upgrade was absolutely transformative.  I have been a tweaker for almost 5 years now and I have never heard anything close to the impact of the N+.  The highs are so extended and clear, and the bass... I could easily hear (and almost feel) the difference in the bass from my bedroom, one floor above my listening room.  One very respected audiophile recently wrote that the 55N+ could be best amp he has ever heard.  Every CD in my collection now sounds different, and way better.
IMO, if you build a stock AKSA and listen for a while, you know (like YOU do) that the AKSA is very much for real.  You can be assured that the N and N+ extend the muscle and finesse that Hugh designs into his amps and IMO are very much worth the relatively modest time and expense it takes to get there.
Good luck,
Peter
Greg Erskine
Re: AKSA manual and Nirvana details?
« Reply #2 on: 25 Jan 2005, 09:27 pm »
Quote from: Johnny
Greetings all!
Johnny, my AKSA 55 1.6 has been going for almost 3 years and it hard to imagine a N or N+ being that much better. I also building a new N+ because I couldn't bring myself to pull apart the old beast.
Is yours a version 1.6 or 2? They are a little different and there could be minor issues for the N+ upgrade. I'm sure Hugh will let you know.
AKSA
« Reply #3 on: 26 Jan 2005, 12:38 am »
John,
Peter (aka PSP) is exactly right;  and while the 1.6 version is not precisely the same layout the mods are identical as electrically the 1.6 and the 2 are the same.
Hope this is helpful,
Hugh
Johnny
« Reply #4 on: 26 Jan 2005, 05:11 pm »
Thanks to all for your comments.
So the Nirvana upgrade entails about 10-20 component swaps per module?
Might I be given a parts count at least?  :notworthy:
And the N+ enatails many fewer, but more expensive parts (such as Black Gates   :idea: )
My modules are 2.0. I recall that they were just out at the time of purchase, but the updated construction manual was still in the works. I can see why the documentation is not freely distributed, but having bought into an AKSA, I'd like to think I'm entitled to the best available documentation.  :violin:
Cheers!
John
AKSA
« Reply #5 on: 26 Jan 2005, 08:21 pm »
John,
Entirely reasonable....... you have every right to the documentation for the equipment you have, but you are free to decline purchase second hand if the documentation is unavailable.
The sonics of the stock AKSA are 7/10.  Nirvana is 8/10.  Nirvana Plus is 9.2/10.  These figures are subjective, based on general consensus.
Replacement components are around six per module for the Nirvana, and 10 for the N+.  Capacitors, resistors and operating points are involved;  it's difficult to explain simply as a replacement.
As a general rule, I don't release digital documentation of my designs because this market is very aggressive and by and large IP cannot be protected.
Hope this clears things up,
Hugh
Al Garay
« Reply #6 on: 27 Jan 2005, 07:25 am »
Johny,
This is not like buying a commercial product off the shelf where you can expect to have documentation readily available. The AKSA documentation has the detail schematics and parts list that allow you to build the amp without paying a fee to Hugh. That's why this is an issue of protecting intellectual property and making sure Hugh continues to get the resources to keep AKSA alive.
You should contact Hugh for the exact cost for the N+ upgrade. I was surprised that it was much lower than I expected since I already had the N upgrade.
Al
AKSA
« Reply #7 on: 27 Jan 2005, 10:09 am »
Thanks Al,
It turns out I was mistaken, and John had indeed bought the AKSA kit from me;  I just didn't recognize him from his forum name!!
We've since PMed each other, and when he decides what to do next I will send him the documentation he does not have.
Hugh
