FS: Paradigm Millenia 30 LCR Speaker Black Chrome Finish SOLD SOLD SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 637 times.
kgturner
SOLD
SOLD
SOLD
SOLD
I am selling my Paradigm Millenia 30 LCR Speaker. I purchased it used and have been using it for a few months as my center channel speaker. I had intended to purchase a pair for Left & Right as well. There's
nothing wrong with the speaker, my wife just prefers the sound from our Klipsch G28.
This speaker lists for $850 MSRP and the cheapest new price I've ever seen is $660.
I don't have the original box, but I will pack it for safe transport. I've been buying, selling, and shipping high end gear for over a decade so rest assured you will receive the speaker in excellent condition. I have the original wall mounting bracket as well.
The only condition issue is what appears to be a small paint smudge on the back of the speaker. It arrived to me with this smudge. Looks like the previous owner had painted his room and mounted the speaker before the paint was fully dry. It isn't visible while mounted and I'll do my best to clean it off at the buyer's request. It never bothered me because I can't see it.
Specifications:
DESIGN:
5-driver, 2-way acoustic suspension, LCR, on-wall / shelf-mounted
FREQUENCY RESPONSE ON-AXIS:
±2 dB from 110 Hz - 20 kHz
FREQUENCY RESPONSE 30° OFF-AXIS:
±2 dB from 110 Hz - 18 kHz
CROSSOVER:
2nd-order electro-acoustic at 2.0 kHz
HIGH FREQUENCY DRIVER:
25-mm (1 in) S-PAL™ dome, ferro-fluid damped / cooled, die-cast heatsink chassis
MID/BASS FREQUENCY DRIVER:
Two 140-mm (5-1/2 in) MLP™ cones, 38-mm (1-1/2 in) dual-layer voice-coils, HTD™ system die-cast heatsink chassis
LOW FREQUENCY DRIVER:
Two 140-mm (5-1/2 in) mineral-filled polypropylene cones, 38-mm (1-1/2 in) dual-layer voice-coils, HTD™ system die-cast heatsink chassis
LOW FREQUENCY EXTENSION:
76 Hz (DIN)
SENSITIVITY ROOM / ANECHOIC:
94 dB / 91 dB
IMPEDANCE:
Compatible with 8 ohms
WEIGHT:
17.6 lbs. (8 kg)
DIMENSIONS:
H x W x D 35.375" × 5.875" × 5.375" (89.9cm × 14.9cm × 13.7cm)
SUITABLE AMPLIFIER POWER RANGE:
15 - 200 watts
« Last Edit: 7 Feb 2019, 09:02 pm by kgturner »
