A/V0
0 Members and 1 Guest are viewing this topic. Read 992 times.
ricardojoa
A/V0
« on: 1 Feb 2019, 10:36 pm »
Hi Danny,
Would like to know if this kit is available before i order.
And can you provide the internal volume for the cabinets? I have some parts express curve cabinets believed to be 30 liters and would like to see if they woud fit. What is the sensitivity of these speakers?
Thanks in advanced!
Danny Richie
    • http://www.gr-research.com
Re: A/V0
« Reply #1 on: 3 Feb 2019, 12:53 am »
Hi Danny,
Thanks in advanced!
If you can order them online, they're available. They ship the day you order if you order early enough in the day.
Cabinet plans are at the bottom of the page if you want to crunch the numbers.
From the webpage:
2-way bass reflex design
Simple parallel network
1 inch GR-T3 soft dome tweeter
M-130 5.25 inch composite paper woofer with phase plug type dust cap, polymer chassis, and vented Kapton voice coil.
Frequency response is as good as +/-1.75dB
-3dB is 50Hz
Sensitivity is 86 dB (1watt/1m)
Recommended amplification is 8-100 watts RMS
Impedance 8 ohms nominal with a 6.5 ohm minimal dip.
Dimensions: 35.75 " h (plus base and floor spikes) x 7" w x 7 " d.
