Is there a way that I can access the hdd that's attached to the BDP-3?
0 Members and 1 Guest are viewing this topic. Read 708 times.
Hoiman
I wonder if it's possible to access the hdd that is attached to the BDP-3, via the network so I can copy new music to the hdd without disconnecting the hdd from the BDP-3?
I'm using a win10 64bit machine.
unincognito
    • bryston.com
You'll need to go into you windows features and enable SMB 1
https://support.wdc.com/knowledgebase/answer.aspx?ID=20736
Chris
Hoiman
Thanks that is it.
