Sensaphonics IEM Possible fluid build up?
0 Members and 1 Guest are viewing this topic. Read 925 times.
smash
« on: 31 Jan 2019, 06:37 pm »
Hi everyone,
I've had my Sensaphonics IEMS for a bit over a year now. Sometimes the right ear sounds muffled, but if I move my jaw around, the sound comes through clearly again for a few minutes. I'm thinking there's either buildup in there. I emailed Sensaphonics and they said they'd need me to ship them in and it'd cost $250 for service.
Are there any other trouble shooting things I should try before spending $250 on something potentially easily fixed?
dB Cooper
Re: Sensaphonics IEM Possible fluid build up?
« Reply #1 on: 4 Feb 2019, 05:04 am »
$250 sounds like s 'swap out' deal, probably transplanting the existing drivers to a remanufactured housing.
Make sure the channel isn't clogged with wax. My sensaphonics sleeves for my now-sold Shures came with a little wire tool for digging it out. Shure considered filter replacement a send-it-in process unlike  the Etymotics which are supplied with a filter changing tool. If they're charging $250 just to change filters, that's a ripoff IMO. I'd ask them for specifics on what your $250 is buying you. For $100 more than that, you can buy a brand new pair of TOTL Etymotic ER4 SR's or XR's which are user- serviceable to a large extent.
I have soured on the 'value proposition' of customs. They're really expensive... None seem to deliver the level of isolation promised (universal fit provides just as good isolation once you find ones that seal and fit well... and worst of all, your ears internal shape actually changes subtly over time*, potentially ruining your $$$ investment; they may only be effective for 2-4 years. The best universal fit tips for me have turned out to be Spin Fit CP240M dual flange, $10 a pair from Amazon. They do just as good a job as customs for me and are a lot easier to clean than memory foam tips and last longer. Theoretically, triple flange is better... theoretically. In practice I have found that what fits best, isolates best, which in my particular ears are the Spin-Fit dual flanges. With all these YMMV of course.
*I was told this by the audiologist who did my impressions for my Shures.
« Reply #2 on: 4 Feb 2019, 03:38 pm »
I have a pair of Sensaphonics that I never use because my ears changed shape slightly and I can't get a good seal anymore :(  I've switched over to universal fit IEMs now and am much happier.
No experience with fluid buildup, sorry.
