3bsst2 hum
0 Members and 1 Guest are viewing this topic. Read 1064 times.
nwmatt
3bsst2 hum
« on: 31 Jan 2019, 07:33 am »
i have a 3bsst2 that is about 6 years old and i am hearing a mechanical hum that is audible from about 2 feet , is this normal ?any ideas what might be the cause?
Mag
Re: 3bsst2 hum
« Reply #1 on: 31 Jan 2019, 11:10 am »
No, my amps are silent can't here them at all and they are on.
Had a hum years ago when connected to an av/receiver. Had to move input selector to input that was not being used. :smoke:
techguy0192
Re: 3bsst2 hum
« Reply #2 on: 31 Jan 2019, 01:37 pm »
Have you tried disconnecting all cables?  This will let you know if the amp is truly the source of the hum.
Elizabeth
Re: 3bsst2 hum
« Reply #3 on: 31 Jan 2019, 02:53 pm »
I beleve the op is saying the noise is a MECHANICAL HUM from the chassis of the amplifier.
This could be due to DC on the AC line.. or a loose transformer. Being a toroid type this isn't loose laminations. but could be the entire transformer, being not solidly bolted down vibrating.
Generally toriod are held by a single bolt through the middle. Tightening it should solve the issue. The bolt may even be sticking out the bottom of the amp.
It should be way more than finger tight, but not super tight! I am sure there is an actual torque spec. Usually the transformer is on a little antivibration pad anyway..
If you are not wanting to tighten this yourself, your dealer should be able to do it under Bryston warranty. They certainly should have someone able to check it under warranty
Ola_S
Re: 3bsst2 hum
« Reply #4 on: 31 Jan 2019, 07:02 pm »
As Elizabeth said, one of the reasons could be DC on the mains (I have the same problem). Try a DC-filter to rule out the DC-option.
David C
  • Don't try and lay no boogie woogie on the king
Re: 3bsst2 hum
« Reply #5 on: 31 Jan 2019, 07:27 pm »
Ola
What DC filter do you recommend ?
nwmatt
Re: 3bsst2 hum
« Reply #6 on: 1 Feb 2019, 02:44 am »
i tightened the transformers and that seem to do the trick !
 thanks all
Elizabeth
Re: 3bsst2 hum
« Reply #7 on: 1 Feb 2019, 02:58 pm »
Great news!!  :thumb:
