Omega & SET speaker cables silver or copper?
0 Members and 1 Guest are viewing this topic. Read 6988 times.
RDavidson
Re: Omega & SET speaker cables silver or copper?
« Reply #20 on: 28 Jul 2019, 03:58 am »
Louis uses Supra as his standard internal wire, but can use ZenWave wire as an upgrade on new orders. I may be wrong, but I don't think Louis has ever sold speaker cables...though that's not a bad idea (if it makes sense for his business). :D
DaveC113
  • ZenWaveAudio.com
« Reply #22 on: 28 Jul 2019, 01:28 pm »
Louis makes some cables using Supra wire I believe, very good value!  :thumb:
Rj67
« Reply #23 on: 28 Jul 2019, 03:18 pm »
Thanks for responses and Dave I just stumbled across your stuff recently when I started reading AC.  Have to check it out and see if there is room in the budget.  Right now I am just running a left over set of BlueJean Canare 4S11 wire.  I found both the Ply 3.4 and Sword available used but will check in with Louis too.
RDavidson
« Reply #24 on: 28 Jul 2019, 03:29 pm »
Oh hey! What do ya know? :D
I've read a lot of good things about Supra cables. I think it'd be hard to go wrong especially when paired with the Supra internal wiring. If you can swing a little coin for ZenWave internal wiring, it's also a very high value upgrade.
