Sold: Emotiva XPR-5
0 Members and 1 Guest are viewing this topic. Read 2216 times.
theater_lover
Sold: Emotiva XPR-5
« on: 27 Jan 2019, 06:14 am »
This has been sold.
Note: Photos show the lights as purple, but they are a solid blue like the reference images.
Nearly perfect condition.  Two very small marks on the right metal piece that can not be seen unless up close.
One of the most powerful, high quality amplifiers available. 400 watts per channel into 8 ohms and 600 watts per channel into 4 ohms, with all channels driven. 575 watts into one channel at 8 Ohms or 1100 watts into one channel driven at 4 Ohms.
Original box, manual, etc included, as well as a heavy duty 20A power cord.
5 channel power house.
Too heavy to ship, but I will deliver in the NJ/NYC area.
$1400 OBO
Add 3% for PayPal.
I also have an Emotiva ERC-3 player for sale.
SPECS
Topology: Fully discrete, dual differential, high current, short signal path Class A/B ampli cation with Optimized Class-HTM power supply topology.
Number of Channels: 5
Power Output (rated power; THD 93 dB at 1 watt (A-weighted).
400 watts / channel (x5); all channels driven; into 8 Ohms.
600 watts / channel (x5); all channels driven; into 4 Ohms.
500 watts / channel (x2); two channels driven; into 8 Ohms.
750 watts / channel (x2); two channels driven; into 4 Ohms.
575 watts / channel (x1); one channel driven; into 8 Ohms.
1100 watts (1 .1 kW) / channel (x1); one channel driven; into 4 Ohms. > 109 dB at rated power (A-weighted).
Damping Factor (8 Ohm load): > 500
Speaker Output Connections: Super heavy duty audiophile speaker binding posts - with clear acrylic insulators and heavy duty gold plated contacts; designed to accept heavy-gauge bare cables, lugs, or banana plugs.
Power Supply: 3.3 kVA toroidal power transformer. 180,000 uF of storage capacitance.
Input sensitivity (for rated power; 8 Ohm load): 1.875 V
Gain: 29 dB
Input Connections: Unbalanced (Tiffany style, audiophile quality, gold plated RCA); one per channel. Balanced (XLR); one per channel. Each input may be independently switched to either unbalanced or balanced.
Input Impedance: 47 kOhms (unbalanced). 22 kOhms (balanced).
Trigger: Trigger Input: 5 - 20 V (AC or DC)
« Last Edit: 21 Feb 2019, 12:18 am by theater_lover »
coolcobramatt
Re: FS: Emotiva XPR-5
« Reply #1 on: 5 Feb 2019, 04:37 pm »
Shame you wont ship  8)
theater_lover
« Reply #2 on: 5 Feb 2019, 05:06 pm »
Anything is possible, but it would likely require a pallet.  The box just isn't up for Fedex/UPS treatment considering the weight.
coolcobramatt
« Reply #3 on: 8 Feb 2019, 07:23 pm »
Check your inbox
theater_lover
« Reply #4 on: 18 Feb 2019, 07:18 pm »
Bump for photos added.
