FS: NO LONGER AVAILABLE Odyssey Audio Stratos Stereo Extreme Power Amp
0 Members and 1 Guest are viewing this topic. Read 901 times.
aaron.luebke
Odyssey Audio Stratos Extreme power amp for sale. Shipping from Rockford, IL or local pickup. $1000 + shipping and fees.
 Chassis is solid but not perfectly clean.
 This is the "Extreme" model but not the Kismet that you may have heard referenced. 180,000uf of capacitance and dual 400va power supplies for 800va total. Should provide 180 watts and run stable from 2 ohm through 8 ohms. She weights in at around 50 lbs - maybe more.
 The balanced inputs will work but are not true balanced inputs, merely unbalanced wired for that connector.
« Last Edit: 3 Feb 2019, 07:41 pm by aaron.luebke »
Tomy2Tone
Re: FS: Odyssey Audio Stratos Stereo Extreme Power Amp
« Reply #1 on: 25 Jan 2019, 06:51 pm »
I thought the black board was an indicator for it being Kismet, no?
aaron.luebke
« Reply #2 on: 25 Jan 2019, 06:53 pm »
Black board is one of the key components but the Symphonic caps and WBT connections seal the deal - I believe.
Never quite sure what Klaus' secret sauce is but this isn't the Kismet.
