B7 and aries G2
0 Members and 1 Guest are viewing this topic. Read 2655 times.
Mike Long
B7 and aries G2
« on: 24 Jan 2019, 05:34 pm »
Trying to set up music library.  Does anyone know if B7 and aries G2 are compatible?  The G2 lit says a compatible DAC must meet the following:
Auralic Aries G2
USB Output: USB Host to compatible DAC ****
**** 'Compatible DAC' means a DAC not requiring a driver for Linux system
Any help will be appreciated.
Thanks Mike
kingdeezie
Re: B7 and aries G2
« Reply #1 on: 24 Jan 2019, 08:11 pm »
I believe that Lampizator used to use Amanero USB modules. I think that is what my Lite 7 used when I had it.
If that is the case, I don't think that Amanero needs a driver for Linux, so it should work. I would think that Auralic could be helpful if you sent them an email.
I am sure someone is using these two products together out there.
wisnon
Re: B7 and aries G2
« Reply #2 on: 31 Jan 2019, 12:31 pm »
Auralic Aries G2
Thanks Mike
Lampi uses Amanero and no driver needed for Linux or Mac.
