Need a new dac
0 Members and 1 Guest are viewing this topic. Read 3021 times.
Mmaxed
Need a new dac
« on: 22 Jan 2019, 01:39 am »
Am in need of a new dac.  Want one with a power source other than just using USB.  Only input I need is USB and maybe optical.  Lets try to keep price under $200.
I.Greyhound Fan
Re: Need a new dac
« Reply #1 on: 22 Jan 2019, 02:12 am »
Schiit Modi, the multibit is $249 base version is $99.
http://www.schiit.com/products/modi-1
timind
  • permanent vacation
Re: Need a new dac
« Reply #2 on: 22 Jan 2019, 01:55 pm »
Topping D50 sells regularly for $250. With some patience you can find new for under $200.
Mmaxed
Re: Need a new dac
« Reply #3 on: 22 Jan 2019, 02:26 pm »
Thanks guys.Looking at them and others.
SMSL Sanskrit 6th
Cambridge Audio DacMagic 100
Seems like there was another on the list that I'm not thinking of now.
I only use it for USB out of a laptop for streaming.
rotarius
Re: Need a new dac
« Reply #4 on: 26 Jan 2019, 02:35 am »
I have owned the Cambridge 100.  The project dac box s2 in this price range is the way to go.  It is better than the cambridge 100 in every possible way.  A bit of a step up from the Musical Fidelity V90 as well but only with an upgraded psu.
Mmaxed
Re: Need a new dac
« Reply #5 on: 27 Jan 2019, 09:02 pm »
I missed your post on the project, but I ordered a Maverick D2 a few days ago.
I.Greyhound Fan
Re: Need a new dac
« Reply #6 on: 27 Jan 2019, 11:16 pm »
Did you get the OPA627 op amp upgrade?  It really needs it.  Sparko op amps sound good in the Maverick as well.  I own a D1 that I don't use any more.
Mmaxed
Re: Need a new dac
« Reply #7 on: 28 Jan 2019, 03:52 am »
I did get the upgrade.
SuperXRSSeattle
Re: Need a new dac
« Reply #8 on: 28 Jan 2019, 07:07 pm »
What upgraded PSU do you recommend?
rotarius
Re: Need a new dac
« Reply #9 on: 28 Jan 2019, 08:31 pm »
I use a linear psu from China purchased on Ebay for 80 bucks. The designer of the dac recommends a psu upgrade.  Even the Allo 5V smps was a step up so I assume the ifi smps would work nicely.
SuperXRSSeattle
Re: Need a new dac
« Reply #10 on: 28 Jan 2019, 08:46 pm »
Thank you for the info! Is 5v what the designer recommends or go higher? Is there a place/link to read up on this? I'm curious who the designer is as well. I will have the S2 here tomorrow so the fun can start!  :)
rollo
  • Rollo Audio Consulting -
Re: Need a new dac
« Reply #11 on: 28 Jan 2019, 09:34 pm »
  Stancor makes VG linear power supplies as well.  Think iFi for that budget, hard to beat.
charles
rotarius
Re: Need a new dac
« Reply #12 on: 28 Jan 2019, 10:23 pm »
There is a very long thread on pink fish media with the dac designer as a contributor.
It has a micro usb power input and it needs to stay around dc 5v.
SuperXRSSeattle
Re: Need a new dac
« Reply #13 on: 28 Jan 2019, 11:12 pm »
Perfect, that's the source. Learned more than I planned and now not sure I want to be in the Project camp even with the reported high quality sound. The firmware updates, if there will be any in the future, has me cautious. If I understand reading between the lines it may be more of a DIY platform moving forward but I need something finished, or long term supported. Here's the link if anyone wants it:
https://pinkfishmedia.net/forum/threads/pro-ject-pre-box-s2-digital-dac.201691/
SuperXRSSeattle
Re: Need a new dac
« Reply #14 on: 28 Jan 2019, 11:17 pm »
charles
Thanks! There was comment at pink on the iFi, FYI. ps. found it p47 of that link, someone said the designer didn't like the iFi. I have no idea on it.
