Subwoofer help with Odyssey Kismet Monoblocks
0 Members and 1 Guest are viewing this topic. Read 2924 times.
Longandstraight
« on: 21 Jan 2019, 05:43 pm »
I am thinking on integrating a couple of subwoofers into my 2 channel system.  My pre is a Micro Zotl 2.0S  with no sub out.  Can I run speaker leads from the mono blocks to the subs? Not quite sure how they are grounded.
Russ
Phil A
Re: Subwoofer help with Odyssey Kismet Monoblocks
« Reply #1 on: 21 Jan 2019, 06:38 pm »
Russ
What subs are you running?  Should be able to.
Davidlsu84
« Reply #2 on: 21 Jan 2019, 07:07 pm »
I'm actually in the que waiting for some monos also, I have 2 REL t9is and it looks very easy to set up with monos
They connect right where the speaker connects in back of amp
Phil A
« Reply #3 on: 21 Jan 2019, 07:34 pm »
Yes - Rels are made that way (I have 4 older ones in 3 different systems).
Phil A
« Reply #4 on: 21 Jan 2019, 07:34 pm »
PS - Welcome to AC!
Davidlsu84
« Reply #5 on: 21 Jan 2019, 07:43 pm »
Thank you Paul I appreciate it, been lurking for a while decided I actually wanted to get serious in this.. Some awesome systems you guys have
JackD
« Reply #6 on: 21 Jan 2019, 10:23 pm »
To the OP the answer is yes.  I ran Vandersteen and then Rythmik subs with multiple Odyssey amps for years.  Works fine.
Longandstraight
« Reply #7 on: 22 Jan 2019, 01:36 pm »
Thanks for replies.  So leads right to the sub and back to the main speakers?  I have always had an AVR and used the LFE out. Just getting serious about 28x22x10 room that will be multi purpose , but built for audio. Going to need a couple of subs to fill it up!!
Russ
JackD
« Reply #8 on: 23 Jan 2019, 03:36 am »
No two pairs of speaker runs. One to the mains and one to the subs then cross the sub "under" the mains if this is for music.  Simple method is to use spades at the amp end for one and bananas for the other pair.  For subs look into a pair of Rythmik F-12's.
opnly bafld
« Reply #9 on: 23 Jan 2019, 04:02 am »
Just follow the REL setup guidelines (worked great for me with a pair of T7i subs).
