Level meters
0 Members and 1 Guest are viewing this topic. Read 2889 times.
zachslc
Level meters
« on: 23 Jan 2005, 09:27 pm »
Has anyone installed level meters on the faceplate of an amp?  (ala vintage macintosh)  I have been poking around the net and I cannot find these for the audio DIYer, but surely they exist, no?  Any experience?  Thanks.
Tinker
    • http://web.access.net.au/~bwilliam/macam
Re: Level meters
« Reply #1 on: 23 Jan 2005, 10:40 pm »
Quote from: zachslc
In a word yes, and they look great, although I must confess my current AKSA setup does not have any.
The expensive part is the swinging-needle galvanic movement. I bought a pair a few years back and they were over $100 each. I imagine this is probably the price of precision. However, you can build a respectable one with a 50uA movement galvanomoter which should only cost about $20 from any electronics store. All you need then is a rectifier and driver circuit, and also an integrator if you want a "peak hold" function. Rod Elliot's circuit is most excellent for this and quite cheaps and easy to build
http://sound.westhost.com/project55.htm
You can also build an LED based one using one of the many driver chips, like this
http://home.maine.rr.com/randylinscott/oct98.htm
I've seen these chips with up to 15 outputs. These chips are about $5-$25 and can be got at local electronics stores like DSE and Jaycar. But you can save a lot of bother by buying one of the many kits available. Do a web search for "VU meter LED kit" etc and you will quickly find something.
To calibrate the thing is quite straightforward. You can use your PC to make a test CD with some sine tones of different volumes from 0dBFS to about -40dBFS in say 3dB steps and play this through your CD player.
At this risk of sounding like a motivational speaker: have fun with it.
   T.
soitstarts
Level meters
« Reply #2 on: 24 Jan 2005, 05:24 am »
Oh yeah, analog VU meters look nice.
http://www.flashstar.com.tw/showroom.html
 Found this LED kit as well
http://electronickits.com/kit/complete/ligh/ck1005.htm
Bit over my head, unfortunatly..
Tinker
Level meters
« Reply #3 on: 24 Jan 2005, 10:14 am »
Quote from: soitstarts
Jaycar sells these flashstars for about $23. I've used them and they work well.
The LM3915 is used a lot in these LED-level applications and Farnell sell them for $10. However, for the price of the kit it's worth it for the boards and miscellany that comes with them. I think Jaycar used to have a silicon chip kit for about the $10 mark. You'd need two: one for each channel.
      T.
PJ
Level meters
« Reply #4 on: 2 Feb 2005, 04:26 am »
I don't know if this is of any help to you guys, but my DJ mixer (Allen & Heath) uses a LB1412 to drive a 12 LED array. I can send the schematic to anyone that is interested, but it looks similar to those already mentioned.
Tinker
Level meters
« Reply #5 on: 2 Feb 2005, 08:06 am »
Quote from: PJ
Excellent choice! If you can find these, they are very cheap. They are probably a better choice than the 3915 I mentioned, although again, if you can buy a complete kit it saves a lot of hassle with a PCB and troubleshooting.
T.
SamL
Level meters
« Reply #6 on: 2 Feb 2005, 09:03 pm »
SIFAM have some 'retro" style VU meters that is really nice but they are expensive too.  http://www.sifam.com/vuppm.lasso
Tinker
Level meters
« Reply #7 on: 4 Feb 2005, 12:12 am »
Quote from: SamL
Radioparts also sell nice meters like this (although not as nice as the retro ones). If cost is no object these certainly look great. However, a lot of what you pay for is the precision of the meter "ballistics." Ifyou don't need BBC, AES, K-20 or one of the other standards then the flashstar meter with a home-brew dB scale is pretty good. It may also be possible to scrounge a retro meter from surplus or antique stores.
Another 2c worth.
T.
