BP17cubed Balance Control
0 Members and 1 Guest are viewing this topic. Read 1136 times.
gberger
  • Check 6
« on: 20 Jan 2019, 09:11 pm »
I had attenuated my left speaker with two pushes of the left balance control button (2db correction).Reorienting my speakers, I no longer need the attenuation. I've tried several pushes on the right channel button, but the green light remains ON for the left channel.  (Pushing the left channel button doesn't help!)
I've tried unplugging the unit and letting it sit for some time. This doesn't help.
How do I get back to the factory-set balance?
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP17cubed Balance Control
« Reply #1 on: 20 Jan 2019, 09:19 pm »
Hi
Please email Mike.
[email protected]
gberger
  • Check 6
« Reply #2 on: 20 Jan 2019, 11:23 pm »
Jamers,
Tried to e-mail mike per your address, viz.,  [email protected]
Mall rejected
The following message to <[email protected]> was undeliverable.
The reason for the problem:
5.1.0 - Unknown address error 550-'5.1.1 <[email protected]>: Recipient address rejected: User unknown in virtual mailbox table'
Reporting-MTA: dns; pmta11.teksavvy.com
George
Pundamilia
« Reply #3 on: 20 Jan 2019, 11:28 pm »
Try putting two 't's in Pickett.
gberger
  • Check 6
« Reply #4 on: 20 Jan 2019, 11:35 pm »
James,
That worked.  Thanks
George
gberger
  • Check 6
« Reply #5 on: 22 Jan 2019, 01:37 am »
Problem solved.
Thank You, Mike
George
