FS: CANCELLED VooDoo Audio Thunder Power Cord 6ft CANCELLED
0 Members and 1 Guest are viewing this topic. Read 703 times.
ErikMi
They are in perfect condition, absolute 9/10  New they are $650 each..
These are not often available and are wonderful PC's. I had them custom made by VooDoo to use with a set of powered speakers that use the C7 connectors, but they would be great on anything that uses a C7 iec... No one else makes a C7 this overbuilt..
VooDoo's comments:
The Thunder Powercord is hand built constructed with #9 AWG high-purity silver-clad copper wire and terminated with the cryogenically treated gold-plated VooDoo PowerPhase IEC Connector and AC Plug. Each strand of the lead and neutral conductors is insulated with Teflon dielectric to suppress AC noise caused by micro-arcing within the lay of the individual strands that make up the conductors.
The Thunder is 100% protected from invasive EMI and RFI with heavy-gauge copper braid shielding. The cord body is sheathed with double layers of abrasion-resistant polyethylene mesh for maximum durability and optimal flexibility. All wire and connectors used to build the Thunder is cryogenically treated in our proprietary cold fusionTM deep-immersion process to structurally align and fuse the metallurgical molecular bond in the conductive metals for less noise and lower line resistance.
« Last Edit: 23 Jan 2019, 03:43 pm by ErikMi »
