**SOLD** Audioengine D1 DAC & Headphone Amp with Pre-Out - USB & Optical Input
0 Members and 1 Guest are viewing this topic. Read 539 times.
sean619
I am the original owner of this excellent sounding DAC / headphone amp.
Selling as my new Peachtree amp has a built in headphone amp & DAC.
All of the original accessories and packaging will be included.
Price: $105
I will ship anywhere in the USA for $13 using USPS Priority Mail. Will also ship to Canada.
I will cover Paypal fees.
Audiogon user: seanheis1
Thanks for looking!
Includes:
USB Cable, RCA cable, Product Manual, Microfiber bag, Original Boxes
GENERAL SPECIFICATIONS
DAC type:
USB and Optical
Inputs:
USB audio SPDIF Optical
D/A converter
AKM4396
USB transfer mode
Asynchronous dual clock
USB controller
TI1020B
USB device class
Type 1.1 or above
Input bit depth
16 bit, 24 bit
Input sample rate (USB)
32kHz-96kHz native playback
188.2kHz & 192kHz re-sampled to 96kHz
Input sample rate (optical)
32kHz-192kHz native playback
Outputs
Analog RCA L/R stereo
Analog 3.5mm mini-jack stereo
Full-scale output level
2.0V RMS
Output impedance
2 ohms
Recommended headphone impedance range
10 ohms to 10K ohms
Headphone amplifier
OPA2134
Optical receiver
CS8416
Frequency response
10Hz-25KHz (+/- 0.5dB)
SNR
(DC to 20 kHz) >110dB
THD+N
(1kHz FS 96kS/s) <0.0025% Crosstalk
-85db
Input bit depth
16 bit, 24 bit
Power requirement
USB 5V DC, 200mA
USB power filtering
2-stage redundant regulation
Product dimensions
3.5×3.75×1″ (89x95x25mm)
Shipping weight
1.0lbs (0.5kg)
Environmental
Operating Temperature: 32 to 95 degrees F Non-operating Temp: -4 to 113 degrees F Relative Humidity: 5% to 95% non-condensing
D1 Internal Converter
The D1 uses the AK4396 DAC, which is well-regarded for its low noise and high fidelity. Due to the high signal-to-noise specs of the AK4396 and the added benefit of double redundancy power source conversion and filtering, the D1 presents impressive low noise and low distortion characteristics. The D1 can process digital audio at any bit depth up to 24-bits and any sample rate up to 192kHz.
D1 Headphone Amplifier
The D1 includes a headphone amp based on the TI OPA2134 low noise opamp. The high-performance headphone output was designed for a wide range of headphones and will satisfy even the most demanding headphone enthusiasts.
D1 Power
The D1 is powered directly from the USB bus and power is passed through two stages of regulation to ensure no USB bus power variations affect the audio quality.
D1 Volume Control
Volume is controlled directly from the D1 front panel via the digitally-controlled analog potentiometer.
« Last Edit: 19 Jan 2019, 07:06 am by sean619 »
