B&W Speakers with NuPrime?
0 Members and 1 Guest are viewing this topic. Read 1565 times.
peacefulcargo
« on: 13 Jan 2019, 02:58 pm »
Hi Folks Are any of you using NuPrime amplifiers with B&W 800s? Great to have thoughts as I would be buying without hearing due to my geographical location. Thanks
Samoyed
Re: B&W Speakers with NuPrime?
« Reply #1 on: 13 Jan 2019, 06:05 pm »
Where are you?
John Casler is your man in the U.S.
toocool4
« Reply #2 on: 13 Jan 2019, 06:31 pm »
Not sure which one you are buying and if you are buying new or used, if you are outlaying a lot of money? I would not buy anything if I cannot listen to it first, it could be an expensive mistake to make. Also never go by someone else’s word, best to always use your own ears.
Samoyed
« Reply #3 on: 13 Jan 2019, 06:33 pm »
Call John.
daniele_g
« Reply #4 on: 21 Jan 2019, 09:44 am »
my brother uses ST10's with 804D2's (ARC LS25 preamp): I was astonished by sound quality (and my brotehr was, too). I like the combo very very much.
reference power amps for my brother in same set up: ARC D115 and ARC 100.2.
