***> SOLD
0 Members and 1 Guest are viewing this topic. Read 854 times.
Mr Peabody
***> SOLD
« on: 13 Jan 2019, 04:57 am »
This is the silver version, but it's more of a mat silver, pics to come or by request if not showing.  I am original owner in smoke free home, the unit is less than a year old, I still have box, manual, remote, everything, and is mint.  This would leave slightly over a year left on warranty for you.  Original retail was $5k.
The only reason I'm selling this gem, I ended up buying a preamp DAC and no longer need this one.  It is honestly one of the quietest backgrounds I've heard in digital playback.  Check the Hegel site for links to reviews, still a current model.
I'm asking $3,000.00 omo
From the website:
The HD30 is the ultimate digital control center. It does everything you can dream of, and does so with world-class quality. There is an abundance of inputs, ranging from balanced AES/EBU and BNC connectors, to Network and USB connections - with the latter also accepting DSD signals. The built-in volume attenuator allows you to connect directly to a power amplifier or a pair of active loudspeakers. Highly advanced power supplies and careful lay-out brings the noise floor down towards a mindblowing -150dB. In short... Do you even dare to try it?
Whether you choose to use Apple AirPlay, a CD-player, a computer or any other device. The HD30 will bring all the music and enthusiasm that exists in the recording.
Technical Details
DAC resolution: Dual mono 32 bit/192 kHz multilevel sigma-delta DAC
Line output: 2.6 VRMS
Digital inputs: 1 coaxial, 3 optical, 1 USB, 1 ethernet, 1 BNC, 1 AES/EBU
Analog outputs: 1 fixed line level (RCA), 1 fixed line level (Balanced XLR)
Distortion: Typical 0.0005%
Frequency response: 0 Hz - 50 kHz
Noise floor: Typically -150 dB
Power supply: Separate torodial transformers for analog/digital 54,000 uF capacitors
Output impedance: 22 ohms unbalanced and 44 ohms balanced
Control input: 1 IR-direct mini-jack
Finish Black and Silver
Dimensions/weight: 8cm (10cm w/feet) x 43cm x 31cm (HxWxD), 6,5 Kg
Dimensions/weight US: 3.14" (3.93" w/feet) x 16.93" x 12.20" (HxBxD), weight 14.3lbs
https://www.hegel.com/products/dac/hd30
« Last Edit: 27 Jan 2019, 02:47 am by Mr Peabody »
