Model T Signature with 28b3 or Active?
0 Members and 1 Guest are viewing this topic. Read 1862 times.
Christo22
« on: 12 Jan 2019, 01:40 pm »
Just ordered a pair of Model T Signatures with passive external crossovers.
Two options now:
1. Passive with a pair of 28b3?
2. Or for the same price...an active setup with a BAX1 and smaller amps. I already have a 4b3 that I would just keep.
...That’s the reason why I went with Sigs. Flexibility... and to be able to ask myself that type of question...
What do you think?
Re: Model T Signature with 28b3 or Active?
« Reply #1 on: 12 Jan 2019, 02:03 pm »
Have run 3 different active speakers over the last 15 years and would never go back.
bud1451
« Reply #2 on: 12 Jan 2019, 03:09 pm »
I had a 4b3 powering a set of Model T Signatures with no issues whatsoever. Unless you listen extremely loud or have a very large room I’m sure you’ll be more than happy with your current amp powering the sigs.
Christo22
« Reply #3 on: 12 Jan 2019, 03:11 pm »
Ok.
Are you using the Bryston cables with your crossover?
I did order a set.
bud1451
« Reply #4 on: 12 Jan 2019, 03:18 pm »
Ok.
I did order a set.
No just some regular 10 gauge speaker cables
Christo22
« Reply #5 on: 12 Jan 2019, 03:26 pm »
Ok.
How did you mange then to get the one that goes from your 4b3 single pair to the crossover triple pair?
bud1451
« Reply #6 on: 12 Jan 2019, 03:35 pm »
The PAX 1 external crossover comes with jumpers for single wire from amp or you can biwire or triwire from amp...remove some or all jumpers from crossover.
Christo22
« Reply #7 on: 12 Jan 2019, 03:46 pm »
Ok.
Dam*!
Maybe I should just go that way then...
Have already a very nice pair of XLO Signature shotguns.
So if I get you right, should I return my passive crossovers and custom cables.
Buy a BAX now... and be even closer to my active setup...
Right?
bud1451
« Reply #8 on: 12 Jan 2019, 03:55 pm »
OOPS.....I meant PAX 1 passive crossover not BAX 1......
But if you really want to go active then all you need is a couple 2.5b3 or 3b3
I was active with 2 3bsst and a 4bsst but unfortunately couldn’t afford the cubed series.
bud1451
« Reply #9 on: 12 Jan 2019, 04:00 pm »
Just a thought buy 2 more amps now and passively triamp into the pax ...later on buy the Bax
Christo22
« Reply #10 on: 12 Jan 2019, 04:11 pm »
Ok. What is your setup now?
PAX1?
It’s confusing.
You still have your Model T?
PX1... that’s what I got right now.
Christo22
« Reply #11 on: 12 Jan 2019, 04:32 pm »
Found it online.
Just a regular cable will work.
See picture.
You still needs 3 pairs from the Xover to the Model Ts.
bud1451
« Reply #12 on: 12 Jan 2019, 04:39 pm »
I’ve owned the Model T internal passive & the Signatures both active & passive, also the Mini Ts. Bryston makes an excellent speaker, I recommend them to everyone. I have since moved on as I like to try different speakers.
Passive triamping isn’t the best but you’ll be one step closer to active.... my opinion a couple of 2.5b3 and  your 4b3 will be sufficient but you could go with the 3b3 if funds permit.
Christo22
« Reply #13 on: 12 Jan 2019, 04:48 pm »
Same here.
Had the Mini Ts twice. (Appart & house).
Also had the Model Ts internal passive.
Tried other things and going back to Bryston.
... so I also agree that Bryston via Axiom build very good speakers. 😉
Until I have the money to get a BAX-1 and extra amps, I’ll use the diagram above.
adol290
« Reply #14 on: 12 Jan 2019, 06:51 pm »
I had the Model T passive with the 28b.
Then went to the Model T SIgnature version passive. Better sound in my ears.
Then to the Model T active with the BAX-1 crossover. Used a pair of 7b3's for the bottom end,
 and a pair of 4b3's for the mid and highs. By far this is the best sounding setup.
So I would highly recommend going active as opposed to 28b's with the passive version.
You will not be disappointed.
BTW. I also tried a 4b3 for the Bass on the active model T's. The Bass was not nearly as
 good compared to having the 7b3's on the bass.
Christo22
« Reply #15 on: 18 Jan 2019, 01:51 am »
Ok. Thanks adol290.
Great overview.
Already have a 4b3.
I was thinking more of a second 4b3 for the MIDS and maybe a 2.5b3 for the HIGHS.
++ room friendly going that way...
