AV123 RS550's and Bigfoot, MODIFIED Including other X-Series Speakers
0 Members and 1 Guest are viewing this topic. Read 6392 times.
I'm  not sure,  it may  or may not  have included  one, if not,  get  4 of them  and  add  a couple there too
The  Sonicaps g2's are  easier to work with thanthe  Vishay rodersteins as they have  longer  leads
jay
Sorry, you'd only  need 3  as the   center  likely alrady  has  a bypass on the   high pass cap
skeeter99
Oh ok. And since the Voce is a 2-1/2 way it may need them in the midrange as well? I think we may need a Danny Intervention! Haha!
It wold be for the mid in  vocci
I use em on all my caps, they are cheap
skeeter99
Ok I've gotta admit, I'm struggling a bit on the crossover for the X-LS Encore. I can barely get the second Erse cap to wrap the ends of the resistor ... I've got a max crossover board size of 5-1/2" x 9". I slid it in and it fits, barely.
This is the best layout I could come up with. Obviously, I'll make it look nicer than this, but will this work?
Danny Richie
Check this out.
skeeter99
Ok so turn the  tweeters inductor so it's 90 degrees from the woofers? What about the rest?
Danny Richie
Twist together the inductor in the woofer circuit and the resistor in the tweeter circuit on the input side so that you have one input connection.
And follow the connection instructions here: https://www.audiocircle.com/index.php?topic=83325.msg805156#msg805156
Danny Richie
skeeter99
Ok, didn't know I could do that. Thanks!
skeeter99
And don't miss this part about the negative wire: https://www.audiocircle.com/index.php?topic=83325.msg805419#msg805419
Yeah that's exactly what I was going to do :)
