SOLD Logitech Squeezebox with Boulder digital mod and Boulder power supply, $145
0 Members and 1 Guest are viewing this topic. Read 1091 times.
david45
It's been sitting in my closet for over a year. Plugged into wall and it powered up no problem. Power supply is quiet.
$145 + shipping from H3C 0N1
« Last Edit: 12 Jan 2019, 09:11 am by david45 »
David C
  • Don't try and lay no boogie woogie on the king
I’m interested. What is the age of the Touch
Hear Clifford Brown
I'm also interested.
Do you have a receipt or anything indicating the Digital Mod?  I did a search and found this picture and description which says the digital mod includes a 75-ohm WBT NextGen RCA output connector, seen at the right in this photo:
And the description:
"The Digital Only modification is the first level of internal upgrades in the Bolder Cable Company lineup. A Squeezebox with this modification package is intended for use with an external DAC, or in a home theater system where a digital to analog converter is housed in another component. Every Bolder modification package starts with an upgrade to the internal power supply stage of the Squeezebox. All of the power supply capacitors are replaced with a combination of Panasonic FC or Blackgate NC capacitors. Since the internal power supply distributes the current to all the circuit stages in the SB3, these upgrades improve both the digital and analog stages of the Squeezebox. The second half of the digital modification addresses the architecture of the digital output circuit. In the stock SB3, the output of the digital buffer passes through a circuit containing various parts, which includes several inductors and complicated board traces. Wayne has bypassed this portion of the Squeezebox, and installed a proprietary 75-ohm wire, and a 75-ohm WBT NextGen RCA output connector. Now the SB3 has a true 75-ohm output level, which the optimal configuration to interface with a separate digital to analog converter."
david45
Thanks for the interest. I bought it in 2012 from forum member jackman. I just sent him a message and hopefully he can join this conversation.
I had a Logitech SB3 with Boulder digital mod (just like the picture you posted) prior to my SBT and as you said it had a BNC connector (coaxial) as opposed to the regular sb3 without mods.
SB3 vs SBT
Stay tuned
« Last Edit: 12 Jan 2019, 09:17 am by david45 »
skalos
