BCD-3 or BOT>BDP-3>BDA-3 ?
0 Members and 1 Guest are viewing this topic. Read 1563 times.
wplash666
« on: 6 Jan 2019, 02:32 pm »
 I would love to know how they compare SQ wise, the same CD played through the BCD-3 verses ripped with the BOT to a BDP-3 played through a BDA-3.
If there is a clear winner , that would be the route I would take.
alexone
Re: BCD-3 or BOT>BDP-3>BDA-3 ?
« Reply #1 on: 6 Jan 2019, 05:21 pm »
...can the BOT-1 be used with a MPS-2?
al.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 6 Jan 2019, 05:29 pm »
al.
Hi Al - no.
Mag
« Reply #3 on: 6 Jan 2019, 07:02 pm »
I used my own doctored recordings at the dealer with Bryston Active speakers. In that room with the Bdp-3 and BDA-3, the sound IMO was stellar. One recording I recall in particular 'Harmonica' from Once Upon at Time in the West, had a 3D like quality to it that just seemed to float in space, impressive to say the least.
However at home the same recording played on my BCD-3 IMO bettered the BDP BDA-3 combo. Mind you I was comparing with my audio memory, which people will tell you is not a reliable comparison.:smoke:
alexone
« Reply #4 on: 6 Jan 2019, 07:14 pm »
...does the BOT still comes with a wall wart power supply??
thanks,
al.
« Reply #5 on: 6 Jan 2019, 07:26 pm »
thanks,
al.
Hi
Yes a DC version
James
TJ-Sully
« Reply #6 on: 6 Jan 2019, 09:39 pm »
hey wplash, i've often wondered about your question.
I haven't had to pleasure of listening to  either the BDP3 or BDA3. But for what it's worth, i have compared the sound with  Oppo203 transport >> BDA2.  versus  the same tune ripped to my hard drive and played through the BDP1>>BDA2.  And IMO, the BDP1>BDA2 was a clear winner.
Although a more pricey route, the BDP3>BDA3 setup would offer far more flexibility in your overall system vs. a single CD player....
My 2 bits.
Cheers, T.
wplash666
« Reply #7 on: 6 Jan 2019, 10:31 pm »
Thank you for the replies,  :)
