Audio/Video Gear and Systems
Tube-o-phile Circle
JakeJ
Testing Russian 6h13c Hickok 752a
0 Members and 1 Guest are viewing this topic. Read 1401 times.
Pstores
6 Jan 2019, 01:06 pm »
I am assuming I can test these using the same settings as the 6as7. Just thought I’d ask here first. Thanks for the input.
Volunteer
Audio Transformers Consulting
Re: Testing Russian 6h13c Hickok 752a
6 Jan 2019, 03:16 pm »
I dont know these settings, but to avoid surprises seems good you match the 6H13C, the 6AS7 datasheet with the Hickok settings.
http://www.mif.pg.gda.pl/homepages/frank/sheets/113/6/6N13S.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/164/6/6AS7.pdf
Pstores
Reply #2 on:
6 Jan 2019, 04:20 pm »
Thanks for the info.... looks to be the same. Unless I missed something...
Volunteer
Reply #3 on:
6 Jan 2019, 10:53 pm »
You will use as regulator or output position?
Pstores
Reply #4 on:
7 Jan 2019, 11:51 am »
Not sure what your asking FullRange. If you talking about the amp. They are for a Atma-sphere M60 Power Tubes.
Volunteer
Reply #5 on:
7 Jan 2019, 03:21 pm »
This tube can operate as voltage regulator also,
which is a more difficult work than output tube.
Tube-o-phile Circle
JakeJ
