0 Members and 1 Guest are viewing this topic. Read 6289 times.
The question is: When is the air pressure in front of the cone the highest? When it's moving fastest, or when it's at it's peak of excursion?
Thanks John R for answering my question. How did you learn this about maximum acceleration of the cone being the point of maximum pressure? I can't seem to find that information anywhere. Anything you could recommend that I read?
Neither - it's when the acceleration is greatest. If the signal is a sine wave then the peak excursion does also happen to be the maximum acceleration. (With the sign reversed.)
Peak acceleration in the sine wave of the cone movement is at the x zero. At peak excursion acceleration is the lowest.
I'm trying to think up an experiment to make sure I'm wrong about this.
Not sure what kind of experiment you had in mind, but suppose you played a tone at some frequency and SPL and measure the excursion. Then play a tone at half the frequency and same SPL and measure the excursion. If SPL is proportional to velocity then the excursion will be double. If SPL is proportional to acceleration then excursion will be 4x.
THe peak air pressure would be somewhere before maximum excursion forward, of the cone.I am certain there is some complex math which could show the air pressure in front of the cone!As a thought experiment alone, The air cannot move out of the way as fast as the cone is moving forward from the start at the lowest cone position. As the cone accelerates forward the air pressure is building up from a negative to mean air pressure.. past the average in the room probably a little before the cone reaches the midpoint (at least some..) and still building as the cone is moving forward.. As the cone reaches nears the end of the excursion the wave in front of it reaches a maximum, and is already decreasing in pressure at the piston surface as the piston reaches the max forward point (since the velocity of the piston is dropping rapidly).
It's experiencing max acceleration out there, but it's not moving through the air so it can't be transferring energy to accelerate the air and create pressure.
