USB driver
0 Members and 1 Guest are viewing this topic. Read 1551 times.
rustydoglim
USB driver
« on: 26 Dec 2018, 06:58 pm »
A new driver has been released that makes installation much easier.  If you have already installed the previous driver and everything is working, there is no need to update to this new driver.
https://nuprimeaudio.com/wp-content/uploads/2018/12/NuPrime_UsbAudio_v4.55.0_2018-12-21_setup.exe.zip
This driver supports Signed Driver Enforcement and the following Operating systems:
Windows 10 (32-bit and 64-bit)
Windows 8.1 (32-bit and 64-bit)
Windows 8 (32-bit and 64-bit)
Windows 7 (32-bit and 64-bit)
Note:
Windows XP is no longer supported.
Install hotfix KB3033929 for Windows 7
giordy60
Re: USB driver
« Reply #1 on: 27 Dec 2018, 05:13 pm »
great !
but tell us also what has been changed / improved compared to the previous version
otherwise we do not know whether to update the version we have installed  :wink:
rustydoglim
Re: USB driver
« Reply #2 on: 30 Dec 2018, 06:26 pm »
It is only for Windows Signed Driver Enforcement compliance.
840wolf
Re: USB driver
« Reply #3 on: 30 Dec 2018, 08:29 pm »
Thank you Jason. Where the previous driver for Windows 10 on my laptop was a problem, this one downloaded perfectly and everything hooked up right away. Audirvana is now using Asio instead of Wasapi. Thankyou. :D
giordy60
Re: USB driver
« Reply #4 on: 3 Jan 2019, 01:45 pm »
64-bit versions of Windows 10 and 8 include a “driver signature enforcement” feature.
if you disable this function ... all the drivers should work ..... or not?
 :scratch:
rustydoglim
Re: USB driver
« Reply #5 on: 4 Jan 2019, 12:13 am »
You don't need to disable the driver signature enforcement. Either way it will work.
