**SOLD** REL T-5 Subwoofer with Upgraded Neutrik Speakon Connector
0 Members and 1 Guest are viewing this topic. Read 1092 times.
sean619
This REL T5 is in excellent condition (9/10) and experienced low use in a music only system.
If you shine light on it and look closely, you can see hairline scratches in the piano black finish.
Included is an upgraded Neutrik Speakon Connector with spades that sells for $110 new. https://www.audiogon.com/listings/lis990j9-signal-cable-inc-double-run-spk-rel-speakon-cable-subwoofers
Also included is a power cord.
User Manual: https://www.hifigear.co.uk/media/uploads/REL_T5_Manual.pdf
I will cover the Paypal fees.
Audiogon user: seanheis1
Asking Price: $440
Will ship from Seattle to US and Canada
Thanks for looking!
The REL T5 is The Absolute Sound's Golden Ear Award Winner
The T5 is a sonic powerhouse, delivering true deep bass from a small, elegant cube. Measuring less than a cubic foot, the T5 goes where no other REL can and performs to the high sonic standards REL has set without compromise. Every aspect of the T5 from the amplifier and crossover to the driver and cabinet are made with true REL performance in mind.
The T5 is able to achieve shockingly deep & tuneful bass from a modestly sized box. Although the T5 does have limits, they are surprisingly high and even in our massive listening area we were quite impressed at how well the little T5 kept up with our large reference speakers. You will be blown away by the improvements this affordable REL sub will add to almost any audio system.
“A special round of applause is owed my current choice for the ideal mini-sub for music lovers. Fast tight, yet tonally replete, with highly defined pitches, the REL T5 is also remarkably extended–stunning so for a single 8” driver in a sealed box. Musical, superbly natural, and robust and durable, as all RELs are, this is a pocket-sized classic!”
– Neil Gader, The Absolute Sound
Specs:
Enclosure Type: Sealed, downward firing
Woofer (size in inches, type): 8, long-throw
Rated Power:125 watts (Class AB amp)
Connections: Speaker- and line-level; Neutrik (speaker), RCA (LFE and low-level)
Dimensions (W x H x D, inches): 10.5 x 12 x 11.75
« Last Edit: 13 Dec 2018, 06:38 pm by sean619 »
