Rotating power plug disassembly
0 Members and 1 Guest are viewing this topic. Read 2331 times.
Doublej
« on: 7 Dec 2018, 11:08 pm »
I want to run a flat cable extension cord through the space between two kitchen cabinets. The cord will fit fine but only if the plug is removed. Does anyone know if a rotating plug can be easily disassembled and reassembled?
Something like one of these.
https://www.amazon.com/Maximm-Rotating-Extension-Outlet-Grounded/dp/B071XDRQWP/
srb
Re: Rotating power plug disassembly
« Reply #1 on: 7 Dec 2018, 11:29 pm »
I'm actually surprised to see 4 screws on the plug, which looks like it could be disassembled, as most extension cords have molded plugs.
If it does come apart, I'm guessing it wouldn't be very easy to re-attach as the conductors are likely crimped to the terminals and could be difficult to try to re-crimp and/or solder.
It might just be easier to grab a new replacement plug which has screw terminals for the conductors, like this one. https://www.lowes.com/pd/Eaton-15-Amp-125-Volt-White-3-wire/3568876
thunderbrick
  • I'm just not right!
« Reply #2 on: 8 Dec 2018, 01:52 am »
Cut and splice the cord, leaving the rotating plug intact?
Doublej
« Reply #3 on: 8 Dec 2018, 11:57 am »
Steve - thanks for the tip. I will check it out.
thunderbrick - I had thought of the cut and splice but was looking for a more elegant option.
timind
  • permanent vacation
« Reply #4 on: 8 Dec 2018, 01:36 pm »
If the splice is inside the cabinet, that's the way to go.
Phil A
« Reply #5 on: 8 Dec 2018, 01:40 pm »
There are also threads such as these which may provide some options (have not read thru all of it) - https://www.diychatroom.com/f18/ext-cord-inside-cabinets-63352/
Elizabeth
« Reply #7 on: 8 Dec 2018, 10:24 pm »
If you cut the cord so the hot line splice is like four inches from the neutral line splice, up can also TIE the middle between the two splices tightly together  with zip ties to help avoid any pulling apart.  then you could use ordinary wire nuts.
I agree hidden between is where the splice would be good. Or behind so it is invisible to sight.
