Help with BryFI
0 Members and 1 Guest are viewing this topic. Read 1142 times.
rhart
Help with BryFI
« on: 5 Dec 2018, 10:35 pm »
I just received a BryFi today (a used one from a Bryston dealer). I had it going out of the box, but after running an update the thing has become inoperable:
1. I can no longer access the web-based BryFi app on my computer or iPad
2. The stand-alone BryFi app cannot detect the BryFi
2. The power button no longer turns the unit off (I have to hold the power button for 20 seconds)
3. I can connect through Airplay, but there's no volume control (and the volume appears to be at full!)
Anyone have any ideas. I am totally frustrated....
« Last Edit: 13 Dec 2018, 04:21 pm by rhart »
  • The Demo is Everything!
    • http://www.bryston.com
Re: Help with BryFI
« Reply #1 on: 5 Dec 2018, 11:43 pm »
I just received a BryFi today (a used one from a Bryston dealer). I had it going out of the box, but after running an update the thing has become completely useless:
1. I can no longer access the web-based BryFi app on my computer nor iPad
Hi
Where are you located?
james
rhart
Re: Help with BryFI
« Reply #2 on: 5 Dec 2018, 11:58 pm »
I bought the BryFi from an authorized dealer in Montreal.
Re: Help with BryFI
« Reply #3 on: 6 Dec 2018, 12:04 am »
Ok phone Bryston tomorrow and ask for Adam.
James
rhart
Re: Help with BryFI
« Reply #4 on: 6 Dec 2018, 12:16 am »
Ok. Thank you...
rhart
Re: Help with BryFI
« Reply #5 on: 6 Dec 2018, 07:03 pm »
Adam was very helpful. Sent me a new microSD card and all works fine.
« Last Edit: 13 Dec 2018, 04:20 pm by rhart »
