Temple Audio Monoblocks (XLR input) SOLD
0 Members and 1 Guest are viewing this topic. Read 987 times.
« on: 24 Nov 2018, 02:50 pm »
Have moved on and no longer need.  Enjoyed them for 2 years without an issue.  Clear/spritely and neutral/revealing sounding with tight bass, 24 volt, 3 amp, 70 watt output at 8 ohms but can handle 2 ohm loads.  Have carefully chosen wall warts with U.S. power cord connectors, reportedly can even run from batteries.  Paid $735 USD, will sell for $400 USD delivered (in original packaging) to the lower 48.
Very well built little gems (aqua blasted aircraft grade aluminum cabinets) and are definitely not to be compared to low cost overly hyped sounding class T amps.  Note that the Temple Audio monoblocks made an immediate improvement over first generation Channel Island Audio D100 monoblocks in terms of openness, speed, refinement, and especially transparency.  And as class T, they are a naturally balanced design.  Thanks for looking.
References:
http://templeaudio.net/monoblock.html#tabb
http://www.enjoythemusic.com/magazine/equipment/0514/temple_audio_monoblock_amplifiers.htm
« Last Edit: 24 Nov 2018, 07:20 pm by JLM »
Goosepond
  • Virna!
Re: FS: Temple Audio Monoblocks (XLR input)
« Reply #1 on: 24 Nov 2018, 03:46 pm »
PM sent.
Gene
