0 Members and 1 Guest are viewing this topic. Read 3695 times.
Bryston +1
You will be surprised at how little watts are used. I have the 1.6's (granted the 3.6's are larger and slightly less efficient) and a Pass Labs X250 amp (250 wpc 8 ohms, 500 wpc at 4 ohms) and the amp has a meter on it showing when it leaves Class A and switches to Class AB. At loud listening levels it rarely leaves Class A (the amp leaves class A between 20 and 25 watts) except on bass heavy music. The high power makes a difference for instantaneous peaks like you may get in classical music. So the majority of the time I am using way less than 20 wpc even at loud volumes.The Maggies like high current amps though. They will chew up a high power, low current amp and shut it down.You will be fine with the Bryston as others have said. Enjoy the Maggies!Larry
Hi allGetting my first set of Maggie's next week. Can't wait! I have Bryston 4B^3 power amp at 300 wpc. I hear some folks suggest 400-500 watts should be delivered in these suckers.....any thoughts on this?My feeling is the Bryston 4B3 will drive the Maggies effortlessly!Thoughts appreciated. TJ
I powered my 3.7i with the 4b3 with no problems, by far the best sound I’ve had I’m my room(previously Model Ts) ...sold the 3.7i and picking up a pair if 20.7 this week
