0 Members and 1 Guest are viewing this topic. Read 21913 times.
Being low voltage active crossovers can be simple or complex, but passive (or powered) crossovers being high voltage have to remain relatively simple. As the buyer of active speakers it'd be your choice what features to use. My active JBL 708P monitors for instance have 12 user programmable equalization filters, DAC (for digital input), frame/speaker delay (for A/V applications), and bass management for use with subwoofer(s). I find the equalization filters very useful to tame bass anomalies that exist in every residentially sized room.
As most of us know,Meadowlark is back in business with some attractive Actives, especially the Kite/Predator combo paired with a DSP system that allows for fine tuning for room adjustments. Meadowlark Audio is located not too far from me so I might have to pack up my Bamberg S3s - which I really like btw - and drive to see Pat for an A/B comparison. http://www.bambergaudio.com/products/series3/3tmw.phphttp://meadowlarksings.comBelow, meadowlark’s Pat McGinty comments ... taken from another forum:“Master speaker designer Joe D'Appolito lays out the basics of taking useful LF measurements:https://www.audioxpress.com/article/measuring-loudspeaker-low-frequency-responseBack in the day you'd need to spend a bundle on a MLSSA analyzer or equivalent. Now we can get the job done with a Windows based system for just 300 bucks. https://www.parts-express.com/dayto...ed-precision-room-measurement-system--390-792If you're venturing into DSP - which gives you delightfully fine control in the bass - knowing Joe's ideas can make the process of aligning your system so much more fun.”
Hmmmmm. I have read where this thread has gone, and frankly as a non-technical person who likes music and is involved in audio as a necessary element of a music appreciation hobby, the high level like this one above might as well be discussing how to build telecommunication transponders to monitor signals from outer space....
What I did when I was younger, was just kept reading. I picked up stuff by reading the same things over and over and learning the nomenclature little by little.
The first thing I noticed when working on this design (PowerPlay Monitors) was that the frequency response we were able to obtain was flatter than any speaker we had ever done.We could create filters for every dip and peak in the response curve and generate a far flatter plot than possible with a more standard passive crossover design.
Flat frequency response can be a revelation. Proper tone is maintained...
shouty/nasal mids, or 'zingy' highs and no missing sounds from frequency dips. The closer to flat you get, the more it "makes sense" of what you're hearing.
Flat frequency response can be a revelation. Proper tone is maintained so everything sounds "right". Bass, midrange, and treble ranges are balanced (no relative exaggerations that so many quick sale marketeers use to impress unsuspecting customers). No bass bloat, shouty/nasal mids, or 'zingy' highs and no missing sounds from frequency dips. The closer to flat you get, the more it "makes sense" of what you're hearing.
