0 Members and 1 Guest are viewing this topic. Read 21908 times.
I'm really planning on being done with swapping out speakers for a while (no, really, like really really).
I'm currently debating powered vs passive for a 3 way design Jim and Dennis are working on featuring the Be tweeter, AT mid, and 9.5" Satori driver with two 10" passive radiators.I'm really planning on being done with swapping out speakers for a while (no, really, like really really). That has me leaning towards passives. Incorporating the active amp on the back of the active design increases the likelihood that the speaker won't last me 20 years or so. If Hypex stops making that plate amp and one fails 5 years from now, I'd be stuck with a really nice piece of furniture until I could lug them to Jim or Dennis. So I'm leaning passive, just so I can keep swapping amps out over the years. Am I crazy??The other thing I read recommended for any active design is a capacitor in front of the tweeter to protect from any DC spikes from the plate amp. So I guess in that way, passive designs offer some inherent protection already. -Jon
I would ask do you really want to spend the next 20 years with a speaker that you knew wasn't as flat as the one you could have purchased for LESS money when you include not having to buy am amp or speaker wires. Let your ears decide what you like, if you are going to live with these speakers for 20 years choose the best available for your budget.
I already have the amp and speaker wires, so cost doesn't matter. And unfortunately I won't be able to audition the active v passive design, so I'll have to pick.
I know I am still Rip Van Winkle in the brave new world of audio, but three points come to mind about powered speakers that militate against them for me:1. What if the amp function within of of the speakers breaks or just stops working after a long time, and the manufacturer is out of business or more likely say they "can't support" the old version of the amp because it is too old?2. What if you like to modify or adapt the sound of your system to get it warmer or brighter or something? I assume there is nothing you can do with powered speakers. (The only ones I've heard-- except audioengines-- have sounded ok, good, clean, bright, aggressive and anonymous.)3. What if you want to try tubes or use your older amp that's still good but you don't have other speakers. Out of luck, right?I may be wrong about these, but thought I would bring up these considerations that hold me back.
My main concern is the powered dsp amps failing way before the speaker drivers.....other concerns is if that manufacturer goes out of business and or that exact amp model is no longer available....Also lets say that amp model is not available but they have a up grade model would one have to change ALL the amps on the rest of the speakers as well? Or do all dsp amps sound exactly the same?
I've told this story several times over the years here on AC but it's worth repeating:18 years ago I visited a shop and auditioned Paradigm Studio 20s ($800/pair 2-way passive monitor) versus Paradigm Active 20s ($1600/pair 2-way active monitor using same drivers/cabinet). No comparison! Dynamics just jumped. Flat frequency response (a revelation in itself). Bass was super deep and full. I was gobsmacked by the bass alone. Passersby that we were listening to Studio 100s ($2200/pair multiple driver floor stander), but imaging was better on the the Active 20s. You just couldn't get that sound from any other Paradigm (besides the Active 40).That's why I've used active (not just powered) speakers for 15 years. [/i] Those are the exact speakers in my system, thanks for sharing the story. I use the active 40's as bed channels and the active 20's as height channels you see on the stands. I got the Paradigm Shift A2 active speaker for the VOG you see over the sofa:
Some years ago at the defuct SACD.NET forum the kind gentleman CEO from BIS Records Mr.Robert inform us the liked Genelec active speakers that he used in the Bis Mastering studio and he praised the bass transients.Personally I think active speaker are suited to pro-audio market and passive speaker are suited to hifi home audio.
1.) Nearly the same argument for integrating any two or more functions into one cabinet. It's a gamble to save now and possibly pay later or just pay more up front. But integration has it's own benefits (saves space, cables, manufacturer picks synergistic matches - assuming you trust the manufacturer enough to buy his gear to start with).2.) Most cheaper active monitors (under say $500 each or found at Guitar Center) do sound as you described, but when compared to similarly priced passive speakers (when taking the cost of amplification into account) beat the pants off them. Expensive passive speakers sound dull, bloated, colored, and lack detail compared to quality active monitors. Active studio monitors are workhorses, meant to dig into the truth versus home passive speakers that are meant to tickle particular fancies. The question is, are you ready for the truth or do you want to chase your tail to satisfy what entertains you?3.) Bryston has a solution for those who want active and yet pick their own amps, but it's bulky, complex, very expensive, and could sound like crap when you're done inventing your own recipe. And besides, active have many sonic advantages, some of which I spelled out above, that make passive obsolete.
Hi,Could you suggest some active speakers that you think highly of? I know you like the cheaper JBL bookshelf 305, but if you have others that are priced higher but are still great values, I'd love to hear.Thanks,Bill
