Repair headphones or toss them?
0 Members and 1 Guest are viewing this topic. Read 1545 times.
« on: 14 Nov 2018, 06:42 am »
I have a pair of Sennheiser headphones that play fine, but the ear padding foam disintegrated.
Is there factory or aftermarket padding you can order?
toocool4
Re: Repair headphones or toss them?
« Reply #1 on: 14 Nov 2018, 07:56 am »
It would help if you say what model it is?
« Reply #2 on: 14 Nov 2018, 08:45 am »
HD515
« Reply #4 on: 15 Nov 2018, 05:32 am »
Don't live in the UK.
mcgsxr
« Reply #5 on: 15 Nov 2018, 01:08 pm »
Those UK pads off eBay include free shipping.
dB Cooper
« Reply #6 on: 17 Nov 2018, 12:15 am »
Within the UK probably.
Did a little Google and (at least according to one source), the pads are interchangeable between HD598, HD598SE, HD598CS, HD515, HD555, HD595, HD518, so any for those models should work.
Found these aftermarket ones on Amazon but Senn should have OEM ones if you prefer.
