Mini T tweeter
0 Members and 1 Guest are viewing this topic. Read 2891 times.
redbook
  • the music is the blood...........
Mini T tweeter
« on: 13 Nov 2018, 02:36 am »
 I am wondering when did the Mini T's tweeter get changed for the current one with the cast in difuser  I think  that it's a great idea but was curious ...When I order my set will they have the new one? thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Mini T tweeter
« Reply #1 on: 13 Nov 2018, 09:59 am »
Hi redbook
It was about 2 years ago we changed the tweeter
james
veloceleste
Re: Mini T tweeter
« Reply #2 on: 13 Nov 2018, 09:33 pm »
Hi redbook
james
Hi,
Were there three versions of the tweeter, or just two?
2bigears
Re: Mini T tweeter
« Reply #3 on: 13 Nov 2018, 09:59 pm »
 :D are they simple plug and play in two year old Mini's ?  Improvements are good if cost is ok  :D
Re: Mini T tweeter
« Reply #4 on: 13 Nov 2018, 10:48 pm »
Hi,
Just 2
james
Re: Mini T tweeter
« Reply #5 on: 13 Nov 2018, 10:48 pm »
Yes plug and play
james
2bigears
Re: Mini T tweeter
« Reply #6 on: 14 Nov 2018, 12:08 am »
 :D thanks James,  can you set me. Up ?  Is it just a matter of unscrewing them and installing the new improved ?   What will 🐝 the improvements heard ?  Is it soft dome or metallic ? Thanks much,,  :D
Re: Mini T tweeter
« Reply #7 on: 14 Nov 2018, 12:58 am »
Yes just unscrew the old units and replace with the new units.
Email me at [email protected] requesting 2 new tweeters and I will forward for you to service.
james
Re: Mini T tweeter
« Reply #8 on: 14 Nov 2018, 01:05 am »
SUBJECT: New Bryston Tweeter
Hi Folks,
Over the last year we have been developing a new tweeter for the Model T and Model A Series speakers.
Model A Speakers currently in the market already incorporate this new design.
The new tweeter has 4 major changes:
1. A die-cast aluminum face plate for both better rigidity and for cooling. It functions as a heat sink for the tweeter.
2. A new horn design to provide smoother off-axis response above 12 kHz,
3. A larger rear chamber that lowers the resonance frequency further below the crossover region.
4. The new tweeter can also handle significantly more power than the older version.
The new tweeter is retro-fit-able to all existing Model T’s in the field and are being utilized in all current production.
Price of the new replacement tweeter is $90.00 Each.
james
veloceleste
Re: Mini T tweeter
« Reply #9 on: 14 Nov 2018, 11:13 am »
For reference here is a Mini T with original tweeter.
2bigears
Re: Mini T tweeter
« Reply #10 on: 14 Nov 2018, 05:04 pm »
  :D THANKS MUCH veloceleste ,,,, looks like I have the new tweets.  :thumb:   :D
redbook
Re: Mini T tweeter
« Reply #11 on: 14 Nov 2018, 07:52 pm »
 Just to be clear...then the newer current unit  doesn't have the diffuser ? :scratch: Why was it changed ?
redbook
Re: Mini T tweeter
« Reply #12 on: 14 Nov 2018, 07:58 pm »
Hi Folks,
Price of the new replacement tweeter is $90.00 Each.......Thanks James ...so I couldl order these through my local dealer ?
james
servingko
Re: Mini T tweeter
« Reply #13 on: 14 Nov 2018, 08:27 pm »
Are the tweeters exactly the same between models or are there differences between models?  For instance, is the model t tweeter interchangeable with the middle t tweeter?
Re: Mini T tweeter
« Reply #14 on: 14 Nov 2018, 09:15 pm »
Hi
Same drivers and crossovers on all models.  When you choose a specific Bryston speaker you are not choosing quality differences - you are choosing application differences.
james
servingko
Re: Mini T tweeter
« Reply #15 on: 15 Nov 2018, 01:21 pm »
Thank you for the clarification.
