New Directions!! Great clearance deals.
0 Members and 1 Guest are viewing this topic. Read 1098 times.
Bill Baker
    • Musica Bella Audio
« on: 19 Jan 2005, 02:37 am »
WIth Response Audio going in new directions, we are now clearing out many products we have been holding onto. Rather than go into details here, the link below will list all the products (I think) that we are letting go at great prices. Please refresh the page when you get there as it was just updated.
http://www.responseaudio.com/specials.htm
 DIY'ers....CHECK THIS OUT......
For any of you DIY'ers out there that feel comfortable going inside a high current product, I am letting go of a pair of high modified Jolida 200 watt JD3000 mono bloc amplifiers. The reason I mention DIY'er is because one of these amplifiers is blowing a fuse when the relay kicks on. I have not had time to see what is causing this. It was doing this before the mods and happens about 1 of 3 turn-ons. It sounds perfect wehn running. This is the "mechanics special" of the audio world.
 Here's what is in the amps:
 ** SoniCap platinum coupling capacitors (x4 pieces)
 ** Riken 2 watt grid resistors (x4 pieces)
 ** Dale/Vishay 1 watt signal path resistors
 ** High quality Higher capacitance / low ESR power supply caps (x8 pieces)
 ** SoniCap power supply bypass capacitors (x8 pieces)
 ** 24 awg input signal wire / custom shielded
 ** WBT Next-Gen RCA input jacks
 ** MORE!!
 These amps would sell for over $6k with the modifications. I am asking $3,500 + shipping for the pair. Please be advised that these amps will be sold AS-IS. Worst case senerio? Bad transformer?? Simple repair.... bad resistor?
