FS: Matched pair Bendix 6384 (6AR6)
0 Members and 1 Guest are viewing this topic. Read 1292 times.
pstrisik
  • Holding pattern in Audio Nirvana in the PNW!
« on: 11 Nov 2018, 08:17 pm »
One matched pair of Bendix 6384.  Made in USA.  Enhanced, long-life, military version of Tung-Sol 6AR6.  Good flashing, tight bases, shiny pins, stencil intact.  Unused since purchased in 2016 when test results were 4900/3300, 66ma and 5000/3300, 61ma.
$100 each at Tube Depot.  $125 plus $12 to cover shipping anywhere in the US and paypal fee.  Will come with white tube boxes.
Thanks for visiting!   :)
From Tube Depot:
The Bendix 6384 is the most durable 6L6 variant on the planet. If you want to push the limits of what you thought a 6L6 could do, this is the tube for you. The famous Bendix Red Bank vacuum tube factory made legendary tubes for military and aerospace applications. Their tubes were built to be the very best and were known to last many thousands of hours. These 6384 are not only built well, they sound awesome. Their tone is firm and aggressive with no sign of weakness.
If you do not want to re-solder your socket, get the plug and play adapter here: https://tubedepot.com/products/6384-to-6l6-adapter.
From a Vacuum Tube Valley Bendix Shootout:
The base is some kind of ceramic material. The construction is luxurious with all-ceramic spacers and a heater block. The pinout is the same as the obscure Tung-Sol 6AR6, a very similar tube to the 5881 physically but not quite the same electrically. Still, the 6AR6 or 6384 can be easily substituted into a 6L6 socket with rewiring or an adapter, and are rated closely enough to work well, though the 6384 makes the 6AR6 look pathetic. The plate rating is 750 volts at 30 watts, which is outrageous for a 6L6 type and more typical of the infamous Mullard EL37. Simply rewire your amp's sockets, and you can use this "Beastatron".
Tests showed that it is indeed a beast. At 300v 50 mA, distortion was 0.77%, lower than that of a typical Tung-Sol 5881. Peak output was 9.8 volts, far more than most 6L6 types and even better than a KT66. It's a shame that so few modern hi-f amps use 6L6s, as the 6384 is a hot little number. When 500v 75 mA was briefly put into the tube, it continued to work without showing red spots on the plate.
« Last Edit: 17 Nov 2018, 11:28 pm by pstrisik »
pstrisik
Re: FS: Matched pair Bendix 6384 (6AR6)
« Reply #1 on: 17 Nov 2018, 11:27 pm »
 :popcorn:
pstrisik
« Reply #2 on: 31 Dec 2018, 06:32 pm »
bump
