SOLD: Chord Hugo 2 DAC
0 Members and 1 Guest are viewing this topic. Read 779 times.
Cave
« on: 10 Nov 2018, 06:41 pm »
Chord Hugo 2 DAC. No issues. Original box, manual, accessories (see photos).
Asking $1800 $1700. Buyer pays shipping with insurance and any PayPal fees. You can get a ballpark from 97006.
I'll accept a money order as well to save the PP fees.
Ships from 97006 Oregon, pickup is welcome in the metro-Portland area.
Materials: Clamshell precision machined aluminium casing with polycarbonate  buttons, acrylic signal window, and glass viewing portal. Available in a choice of two colours – natural silver, and satin black
Battery: 2x Rechargeable custom Enix Energies 3.7v 9.6Wh Li-ion (lithium-ion (2600mAh) batteries*
Tap length filter: 49,152 – 10 element Pulse Array design
Play time: In excess of seven (7) hours
Charging: Nominal four (4) hours via Micro USB at 1.8amps (fast charge) – Nominal eight (8) hours at 1amp (slow charge)
Connectivity (input): Micro USB (White): 44.1kHz – 768kHz – 16bit – 32bit
Coax via 3.5mm Jack (Red): 44.1kHz – 384kHz – 16bit – 32bit
Dual data mode input (using both BNC coax inputs together): 44.1kHz – 768kHz – 16bit – 32bit
Optical (Green): 44.1kHz – 192kHz – 16bit – 24bit
Connectivity (input wireless): Bluetooth (Apt X) (Blue): 44.1kHz – 48kHz – 16bit
Connectivity (output): 1x ¼” jack headphone output
1x 3.5mm jack headphone output
1x stereo (L & R) RCA output
PCM support: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 358.8kHz, 384kHz, 717.6kHz, and 768kHz.
DSD support: Native playback supported. DSD64 (Single) to DSD512 (Octa-DSD)
Volume control: Digital, activated in 1dB increments. Last known state saved upon shutdown, with exception of line-level mode
Line-level mode: Activated via dual press of middle ‘Source’ and ‘Crossfeed’ buttons. Line level = 3v via all outputs. Reset by power cycle
Power saving mode: Auto-shutdown after ten minutes of input inactivity
Driver support: Driverless with Mac OS X and Linux, driver required for Windows OS
« Last Edit: 30 Nov 2018, 06:24 pm by Cave »
Cave
Re: FS: Chord Hugo 2 DAC
« Reply #1 on: 19 Nov 2018, 06:13 am »
bump
