SOLD - Wilson Audio Cub Loudspeakers with dedicated Sound Anchor Stands
0 Members and 1 Guest are viewing this topic. Read 1925 times.
cytocycle
****SOLD****
NO CRATES will not ship - local pickup in Scottsdale, Arizona 85255
Selling off some of my spare systems that never get used, in a kid-free, animal free, smoke-free home.
Sounds amazing just getting rid of my office system.
Includes a pair of Wilson Audio Cub loudspeakers, and filled Sound Anchor stands designed for the Wilson Cubs and 2 grills that don't stay on which is typical, needs more velcro.
The paint finish has no scratches or marks showing that I can find and sound amazing.
I have it set up with my Line Magnetic SET tube integrated for you to listen and bring some of your favorites CD's.
I have more shrink wrap to warp them for transport but do not have the crates. bring some blankets/towels to take them home in your car.
These can be powered by about anything because of their high efficiency.
Wilson Audio Specialties CUB loudspeaker Specifications
Sidebar 1: Specifications
Description: Two-way, reflex-loaded loudspeaker. Drive-units: 1" inverted metal-dome tweeter, two 6.5" treated-paper cone woofers. Crossover frequency: 1.8kHz. Frequency response: 50Hz-25kHz, ±3dB; 55Hz-22kHz, ±1.5dB. Sensitivity: 94dB/W/m. Nominal/Minimum Impedance: 4 ohms/2.8 ohms at 400Hz. Recommended minimum amplifier power: 7W.
Dimensions: 22" H by 10" W by 22" D (to nearest inch, including crossover cups). Weight: 75 lbs each.
Finishes: black laminate, standard; painted, add $400; wood veneer, add $640.
Serial numbers of units reviewed: 0131 & 0132 (also 0129, 0130 & 0135 in home theater applications).
Price: $5900/pair
Manufacturer: Wilson Audio Specialties, Inc.,
 Web: www.wilsonaudio.com.
« Last Edit: 18 Nov 2018, 01:24 am by cytocycle »
cytocycle
****SOLD****
