DAC-9H shipping now
0 Members and 1 Guest are viewing this topic. Read 3109 times.
rustydoglim
DAC-9H shipping now
« on: 3 Nov 2018, 06:51 pm »
https://nuprimeaudio.com/product/dac-9h/
The DAC-9H differs from DAC-9 with additional balanced 4.4mm ‘Pentaconn’ socket and 3.5mm standard stereo headphone outputs that support Single Ended Unbalanced, Fully Balanced and Active Balanced Ground Driving headphone amplifier.
We only added headphone amp, the rest remains exactly the same.
left channel
    • Everyone wants to date my avatar
Re: DAC-9H shipping now
« Reply #1 on: 7 Nov 2018, 02:03 am »
Interesting! Where would you place the headphone amp on your amp comparison chart?
rustydoglim
« Reply #2 on: 7 Nov 2018, 04:20 am »
It uses the same design as DAC-10H, but without as much power.
RafaPolit
    • www.rafaelpolit.com
« Reply #3 on: 7 Nov 2018, 05:39 am »
While the Sony Balanced connector is an interesting addition, I would have hoped for a more professional 1/4" phone plug rather than the cell-phone earphones 3.5mm connector.
Also, the wording error of "Balance" without the D also found in the back connections is something that should have been corrected.
Strangely enough, the literature on the web page correctly describes the "Balanced" audio connector, yet the case reads "Balance".
I will forever insist that attention to ALL details is important.  If the same 'lack of care' were put into resistor values or cap capacity, then the amp will be really poor.  Why is it less important to write correctly?
Best regards,
Rafa.
left channel
« Reply #4 on: 7 Nov 2018, 06:19 am »
Agreed. The same things bother me too, and affect my perception of the product.
rustydoglim
« Reply #5 on: 8 Nov 2018, 12:40 pm »
Best regards,
Rafa.
There is a much simpler explanation.  Non native English engineers. They can design the best electronics in the world, but handling the language could be a problem.  I reviewed the website but missed the case.
zappan
« Reply #6 on: 8 Nov 2018, 12:46 pm »
Rusty, people here refer to the front panel of the DAC...
If the production has not started yet, you still have the time to correct that too.
rustydoglim
« Reply #7 on: 8 Nov 2018, 12:48 pm »
Actually I am not sure.
I think the use of Balance is correct.
Balanced Connector
But if used alone, it should be Balance.
Any English major here care to comment?
Samoyed
« Reply #8 on: 8 Nov 2018, 02:33 pm »
Well, it depends on the context like so much about English grammar.
left channel
« Reply #9 on: 8 Nov 2018, 05:06 pm »
Balanced Connector
Regardless of whether you can fit "Connector" on there, it's still "Single Ended" and "Balanced":
http://www.bryston.com/products/power_amps/BHA-1.html
I work in localization. We think about these things all the time, even if it makes our heads hurt.
Another thing that makes my head hurt? That low-end 3.5 mm jack. IMHO it should be the professional 1/4" size.
left channel
« Reply #10 on: 8 Nov 2018, 05:07 pm »
[Dupe. Sorry.]
Samoyed
« Reply #11 on: 8 Nov 2018, 05:46 pm »
Nouns, verbs, whatever.  :lol:
rustydoglim
« Reply #12 on: 8 Nov 2018, 05:46 pm »
I disagree.  I think using Balance as a noun for the I/O is correct. But if you want to use Balanced with the context, can't say it is wrong either.
left channel
« Reply #13 on: 8 Nov 2018, 05:53 pm »
The noun is "Connector", even if it's not there. Don't think about it too much or your head will hurt. Just rely on native speakers and industry-standard usage.
rustydoglim
« Reply #14 on: 8 Nov 2018, 05:55 pm »
This is a balanced signal/connector.
This signal/connector is balance.
Singaporean's English isn't too bad either.
https://en.wikipedia.org/wiki/EF_English_Proficiency_Index
left channel
« Reply #15 on: 8 Nov 2018, 06:02 pm »
Singaporean English may actually be more correct in other cases, but "Balanced" and "Single-Ended" are the industry standard.
rustydoglim
« Reply #16 on: 8 Nov 2018, 06:04 pm »
I am just having fun. Whatever, it is already done.  I will ask them to look into this.
left channel
« Reply #17 on: 8 Nov 2018, 06:05 pm »
Yes, in the end we all know where to plug in. :-)
I'm surprised, as in my experience the "9" line includes smooth AKM-based DACs and warm amps, while the "10" line is neutral ESS-based DACs and reference amps. No?
rustydoglim
« Reply #18 on: 8 Nov 2018, 06:26 pm »
Oh, I am talking about the headphone amp, not the DAC section.
Headphone amp is totally different from the DAC and we use discrete transistor to craft the circuit (instead of opamp)
 :thumb:  You guys are paying attention to what I wrote.
left channel
« Reply #19 on: 8 Nov 2018, 06:38 pm »
No worries, I understood (I think). So it has a different amp? Where does it place on your amp comparison chart? As I don't like my STA-6 but very much like my STA-9 and have similar tastes in headphone amplifiers, this is important to me.
