Kenwood KT-8300 Supertuner very good condition -Top FM sound $248 plus shipping
0 Members and 1 Guest are viewing this topic. Read 2590 times.
apt_one
SALE PENDING
Great sounding classic Kenwood tuner- has beaten out many other tuner I tested it again.
One of Kenwood's best. This is a 6 gang stage unit. Really exceptional performance! Very versatile controls, Very good to excellent condition (one nick at bottom edge on right bottom side of faceplate but otherwise excellent. Please email me at [email protected] for more photos. The ones I took are too large for this site. Buyer to pay actual fedex ground shipping charges, if using paypal, please add 3% to grand total. No overseas shipping. You will be hard pressed to find one in better shape.
Will come with a copy of the owner's manual for your reference.
Per fmtunerinfo - "The KT-8300 was a great tuner when new, very sensitive and selective even in stock form. It has the classic Kenwood silver-faced styling (the "gun-metal" gray-faced version of the KT-8300 is the KT-9900), a powerful front end with a 6-gang tuning capacitor, and the potential for top-quality sound after an alignment. The KT-8300's front-panel features include a button to switch the combination multipath/deviation meter, a wide/narrow IF bandwidth button, MPX filter switch, variable output knob and two levels of muting (or muting off). On the back panel, there are fixed and variable RCA outputs, scope outputs, a 75 µS/25 µS FM de-emphasis switch and a dimmer on/off switch. Inside, you'll find two independent filter paths, very much like a 600T (which it somewhat resembles) but without the "middle" path. The KT-8300 uses two 4-pole linear phase LC filters for the wide IF bandwidth setting and three 4-element ceramic filters for narrow mode, rather than the modern 3-pin type."
Description
The Kenwood KT-8300 is designed to the highest standards and is an ideal match for the KA-8300 amplifier.
Specifications
Type: Mono/Stereo Tuner
Tuning Bands: FM, MW
Tuning Scale: Analogue
FM Tuning Range: 88 to 108 MHz
Sensitivity: 1.6uV (FM), 18uV (MW)
Signal to Noise Ratio: 75dB (FM), 50dB (MW)
Distortion: 0.4% (FM)
Selectivity: 110dB (FM), 35dB (MW)
Frequency response: 20Hz to 15kHz (FM)
Output: 750mV (FM), 75mV (MW)
Dimensions: 430 x 149 x 376mm
Weight: 8.5kg
Year: 1976
Email me at [email protected]
Includes:
Copy of Owner's manual
« Last Edit: 2 Nov 2018, 11:50 am by apt_one »
JakeJ
Hi,
I'm interested, PM sent
